230V, 100 Hz, AC, Pure Sine Wave, Power Source
  • 1.3K Views
  • Last Post 31 October 2023
Vasile posted this 25 October 2023
Hello everyone,
I need a power source that can deliver 230V, 100 Hz, AC, Pure Sine Wave. I searched the internet, but mostly because the standard is 50-60 Hz, you will not find it as a standard electrical hardware in stores (online and offline). So it is a "specialized" type of equipment and I did find something from https://novaelectric.com, for example, in the form of frequency converters, inverters and custom made power sources.
My question is: Does anybody know how to make a diy, solid state, power source that does what I just described? A square wave will also do for the moment but pure sine wave is preffered.
P.S.: I know Vidura is skilled in the arts, maybe he is around to help. By the way, Fighter, is there a option to tag people in comments?
Hello everyone,
Fighter posted this 25 October 2023
Hi Vasile,
There is no tagging feature for members just tags for threads, sorry...
But you can send a personal message to Vidura through his profile here (the "Message Me" button) and he will receive a notification in his email inbox through our email system.
  • Vasile
Atti posted this 25 October 2023
Hi.
In theory, it's simple. The practice is of a different nature. For the basic implementation, I would suggest the topology of inverters used in P.V. systems.
That is : PWM sinewave inverter.
You can also use a D-class amplifier topology.
Bottom line. To vary the high frequency signal fill factor within a period. If you need 230V voltage then 325V D.C. DC voltage should be controlled in this way. The control can be arduino or EGS002.
You can find a lot of information about it.  Just an example
baerndorfer posted this 25 October 2023
maybe you should look for 'variable frequency device'
VFD Capacity: 1HP (0.75kW)
Input voltage: 220V, 230V, 240V AC ±15% single phase
Input Frequency: 50Hz or 60Hz
Output voltage: 0 - input voltage three phase
Output Frequency: 0 Hz - 400 Hz (maximum)
Rated current: 4.7 amps
http://www.vfds.org/1hp-vfd-50hz-60hz-220v-single-phase-input-216398.html
have a nice day
Vasile posted this 26 October 2023
Thanks for the tip. Really interesting tech the PWM used for inverters.
Quoting:baerndorfer
I already tryed with VFDs years ago. The problem with them is that the output is squarewave and not sinewave. At least the majority of VFDs are like that because it is cheaper to make a square wave VFD than a sinewave one. They rely on the fact that high induction devices like motors, which VFDs are mainly used for, do not care that much if the input is square or sine.
Shelfordella posted this 28 October 2023
230V rms, peak or peak2peak? How much power?
YoElMiCrO posted this 28 October 2023
@Shelfordella.
I think Atti is right, only with PWM could you make that generator.
A long time ago I made a pure sine inverter for
120Vac @ 60Hz, when where I lived I had to count the hours of mains supply.
I did it with a micro controller and a full-brigge stage in 24Vdc.
I think that exists in the market, you'll just have to tweak something.
Inception posted this 28 October 2023
100 Hz Sine Oscillator ---> 8 bit A-to-D converter ---> 8 MOSFET drivers ---> 8 Binary-weighted power MOSFETs (summed) ---> 256 step sine wave  ---> low or band pass filter ---> Smoothed sine wave generator.
  • AlteredUnity
Vasile posted this 28 October 2023
Quoting:Shelfordella
  • 230V rms.
  • 100 W.
Shelfordella posted this 29 October 2023
Quoting:Vasile
  • 230V rms.
  • 100 W.
Do you have 230V coming out of the mains?
Looking into a (resonant) frequency doubler might be interesting. Will look into it too to see how it works.
