Chaotic Magnetic Pendulum - Free Energy
  • 1K Views
  • Last Post 20 October 2024
Dudeman posted this 17 October 2024
A chaotic magnetic pendulum is a unique system that utilizes the unpredictable motion of a pendulum to generate energy. The setup consists of a pendulum with a magnet at its end, stationary base magnets, energy harvesting coils, a pendulum coil (pulse coil), a timer switch, and a single supercapacitor.
Here's a detailed explanation of how this setup works:
1. Pendulum Motion: The pendulum swings chaotically due to the interaction between its magnet and the fixed base magnets. The chaotic motion results from the unpredictable repulsion and attraction between the magnets, leading to a highly irregular and complex movement pattern.
2. Energy Harvesting: As the pendulum swings near the base, its magnet passes through the energy harvesting coils, inducing a fluctuating magnetic field. This fluctuating field generates electricity in the coils, which is then stored in the single supercapacitor.
3. Pulse Coil and Timer Switch: A timer switch is connected to the pulse coil and the supercapacitor. The timer sends a pulse of current to the pulse coil at specific intervals, depending on the desired pendulum motion and energy transfer. The pulse duration and interval are adjusted to provide enough energy to repel the pendulum's magnet from the base magnets while minimizing energy waste.
4. Preventing Sticking: When the pendulum starts to slow down or about to stop, the timer switch sends a pulse of current to the pulse coil, repelling the pendulum's magnet and ensuring continuous motion.
5. Energy Management: The single supercapacitor stores the energy harvested from the pendulum's swings and provides it to the pulse coil during the pulse intervals. The timer switch ensures efficient energy delivery, preventing waste and maintaining the pendulum's motion.
6. Self-Running Potential: With the timer switch controlling the pulse coil and the supercapacitor continuously recharging from the harvested energy, the chaotic magnetic pendulum setup can potentially achieve self-running operation. The system maintains the pendulum's chaotic motion, generating energy and supplying enough power to keep the pendulum swinging and the system running.
The chaotic magnetic pendulum is an innovative approach to harnessing energy from unpredictable motion. The combination of chaotic motion, magnetic interactions, energy storage, and controlled energy delivery using a timer switch creates the potential for a self-running system. However, careful design and optimization of the components and parameters are crucial to achieving the desired level of autonomy and efficiency.
Jagau posted this 18 October 2024
Hello DudeMan
Could you show me a practical experience of what you write here it would be easier to understand.
Welcome to the forum
YoElMiCrO posted this 18 October 2024
I think it talks about the concept of the parametric oscillator.
A non-linear oscillator, consequently, difficult to control...
Because the equations that describe it are differentials
and according to which, as far as I know, without solutions, at least for the moment.
AlteredUnity posted this 19 October 2024
Here's a brief description of parametric oscillator, and an example of a pendulum being used.
Dudeman posted this 19 October 2024
Just search YouTube for: Chaotic Magnetic Pendulum
Also, how do you embed videos on here?
Fighter posted this 19 October 2024
Hi Dudeman,
For posting a YouTube video the video address must be added in a new line in post as a simple text and the site will detect it as a YouTube video and will render it accordingly:
If you want to add other kind of video (by uploading it from your computer or using an address from a external site) you can use the "Insert/Edit Video" button in editor:
Note: we have a 500 MB size limit for uploading a video, the uploaded file cannot be bigger than that.
If there are any issues just let me know and I'll help.
I don't see any options for that, just a white text box for me to type. No buttons to make my text bold or anything else.
Fighter posted this 20 October 2024
Quoting:Dudeman
This is strange, all our members have all these features available on our site.
Seems there is a problem on your machine, what browser (including version) and operating system are you using ?
Press F12 in your browser then there check the Console, do you see any errors when you're trying to post something in this thread ?
If you're using the phone, these features are disabled on the mobile version of our site (more work is required there to make these features work on phone too). Is the the phone where you're having this issue ?
In that case there is a temporary fix: enable the desktop version of our site in the browser of your phone and you'll see these features.
This is how I do it in Firefox on my phone:
Of course you'll notice by enabling this the layout of the site will be affected in a negative way but this is just a temporary solution for seeing these features on a phone until I'll have some time to do more work on the mobile version of the site.
Sorry about any incovenience but during the site development there was not enough time to work in parallel on the mobile version.
Dudeman posted this 20 October 2024
Ok, I see. I enabled desktop view on my phone and it works now.
Thanks. 👍
I've made minor adjustments to my opening post and added a video as a reference.
Thanks
You're welcome !
