Drag-free motor
  • 587 Views
  • Last Post 26 December 2025
Jagau posted this 09 December 2025
Drag-free motor
Alex Manzanero has demonstrated a simple way to make a drag-free motor.
Using a coil positioned orthogonally in front of a series of 24 pairs of North-South magnets, he built this motor over a year ago. The goal of this experiment is to avoid having a Lenz drag no matter how you do it.
His YouTube channel:
https://www.youtube.com/@alexmanzanero
Several have tried to replicate this without success, and Alex has demonstrated a real result.
I tried it and it works.
When the coil is placed orthogonally in front of the north-south magnets, it lights up its lamp and produces no drag.
Drag-free motor
Jagau posted this 15 December 2025
A picture is worth a thousand words, the conventional one on the right and Alex's on the left.
Lenz's law is canceled on the left when the two opposing north-south magnets pass simultaneously through each end of the coil.
magluvin posted this 22 December 2025
this was a test i did some years ago.
mags
Darediamond posted this 26 December 2025
If you want. To create a drag free motor, go for Garry Stanley Pulsed Motor which is ACTUALLY a Motor Generator when you use High frequency diodes to Make it needed Full Bridge Rectifier needed to power the MotGen Coils and as well Harvest Back E.M.F from them into a Large D.C capacitor Bank.
To build the MotGen, you MUST obey some important simple technical rules. 1 The inner diameter of your Coils must be the diameter of your Neodymium Magnets. The outside diameter of the coils must be the Diameter of your magets plus 2cm. This means that if your Neodymium Magnet is 4cm in diameter, the total Diameter of your Coil must not be less or more than 6cm. This is very mandatory so as to allow for perfect mechanical switching using a Copper Commutator I will teach you how to D.I.Y later.
When you wind the coils to 6cm in diameter and the magnet diameter is 4 cm, it means that 1cm is for pushish away the magneta while 2cm is neutral and the remaining 1cm is for accepting in. To understand this, place two identical coils of 6cm wide besides each other. Now place a 4cm wide magnet on there shared legs. You will see that 1cm part of the neodymium magnet is opened to the core of the coil on the left and another 1cm is opened to the core of the coil on the RIGTH side. Those 1 opened state will act as the switch when you power the coils. As the electromagnet coil of 6cm diameter on the left push the magnet away, the one on the left would accept it in due to law of MAGNETISM which says like poles repels while unlike poles attracts.
  1. Use Copper Wire only to make the coils. The Height of each coil should be the heigh of your neodymium magnet times 2. So if your Neodymium Magnets height is 20mm or 2cm, each of the coils must be 4cm in Heigth. The amount of electromagnets should be any even number which is divicible by 3. So 6, 12 or 18 coils are all good. Each coil must be wound with same size and length of Copper Wire. Your magnet must be Cylindrical. The magnet Diameter determines the size of the Electromagnets to be used as STATOR COILS or Electromagnets.
Jagau posted this 26 December 2025
The engine you're talking about debuted on the Energetic Forum in 2010, 25 years ago, with Skywatcher.
There were 24 pages of discussion about this engine, and I don't see anyone who has managed to build it, including you.
I don't see the point in discussing it if you know how to build it but haven't demonstrated it since 2010.
Show us your expertise.
  • Vasile
You are yourself only not every other people. So if it is hard for you to comprehend simple logical, tactical and technical processes it does not mean it would be hard for others.
I have built and dismantle several mechanical and non-mechanical devices by mearly following manuals .I do not even wait for video evidences of any of the devices I replicated before I kick off trying to replicate them to see if they will work or not and or if they can be improved on as there is no Human invention with 100% efficiency.
So please park aside and let people see road clearly Abeg!!
You are on my thread here make yours please.
If you want to try making something with your 3/4" round plywood with magnets all around, without any technical explanation  you failed. This is not a political or flying saucer forum here, it is a sharing energy forum.
Answer this simple question: why are you asking people to contact you privately on WhatsApp?
