What we know exactly about Don Smith Device
  • 2.6K Views
  • Last Post 26 December 2025
HansKammler posted this 26 September 2025
Hello Community,
Since years a lot of people try to replicate the don smith earth system without luck as I see. So I just want to ask what exactly we know about the machine ? I will concentrated on that what I can see in the original Materials. the Raw input so to speak...
There is a schematic on the net which should be "the device". later I found out there are 2 different circulating. It seems it comes from a patent application but i cant find the patent granted.
So on the Image above I cannot see a L3 output Coil ? inside the tube ? where are the wires for L3 then?
since they differ so much (L3 / Parts omitted...) I don´t upload the various ones . this seems to be misleading to understanding as someone has edited them for confusion.
in one of the Lectures he stated , that parts are missed from disclosure because of investors interests and his security.... but it should be easy to figure out for an HAM operator. Ok. My ham operator told me he don´t know..."
there is a lecture where he Lit 1000 W of indecant Lamps on a Board, while his Demonstrator sits left side from the board...But I don´t know if this was powered from this board or a suitcase.
how big is this MONSTER:
for my it looks like a demonstrator only to look - not the device which powered the light bank ?
what you are thinking ?
I didn´t found ANY good Image of this UNIT on the net ! nowhere.
As I found Dons Website in archive.org , every backup has the big Image of this REMOVED !!
no joke ! all his images are since the 90ties here in archive. Not this unit ! damn
OK What we learn: NST , OILCAP, Primary LC (yellow big CAP) - and white shimmering WHAT ?
where is the battery here ? No powersupply ? Why ?
Why the white core goes away from panel ?
is there a Barker coil in front of device on the Floor ? with 8KV yes ? I cannot believe this.
this we all know Ok...
and the people try to draw schematics from that what they see. I found in the office video exact the device which was used back then:
(in the upper left part)
and lower side: the HIGH Power DSE V3
On inventors Weekend Don told us, that the Amcore transformer is exactly the device he showed 1996 in the suitcase ! But this is a completely different device than the Earth system he showed 1996 in my opinion.
So what we exactly know for sure about this device ?
The NST is a short Circuit ! No Sparkgap, no charge Capacitor -> OK
then:
if you put in on the same speakerwire (L1 which goes arround the AMC) and create a short ! VERY BAD ! Don´t do that !! you kill the NST in seconds.
OR: if you use it Bifiar as we can see -> you supply the 2 wires with HV one next to the other
AND LET THE ENDS OPEN. If my theory is right you have a cap coupling in the other coils (E Field)
but this is theory and I was not able to confirm on testbench at the moment.
Found another image:
How are the coils winded ?
Could you see how the wires are going from and to ?
my friends told me the could see its POC style. But I´m not sure. and IF yes . which one ?
l1 to L2
or L1A to L1B to L2
or L2A to L2B to L1 ? Crazy...
I hope this is not boring ? sometimes its good to brainstorm and check the way we are of...
some Images from my archive:
the cap should go between L2A and L2B on the middle TAB and goes to Earth . This should do a DAM for the ground electrons. Because the resistance is High for the rotating electrons in the L2A/B Reactor.
But this system needs then a third coil (L3) loose coupled (to not affect the NST Supply)  to pull the electrons out of the Tank for using with Capbank / Loads
Inductive power out with diodebridge under metal and smoothing caps in parallel.
Coke Machine Japan. Power inverter pcb. seems to be out of the box. not self builded. whats next to it on the table ? the rest of the ambient device ?
Hello Community,
then:
l1 to L2
or L1A to L1B to L2
baerndorfer posted this 27 September 2025
How i see Don Smith....
he use HV-module with around 30kHz to energize his coil. he did not use sinewave! he use trigger with very sharp edges (like tesla use in his zero-transformer). the signal gets amplified with his air-coil system to reach 20kV minimum (the more the better).
in his drawings he showed that his L2 coil is wound in a way, that on one leg he has 'voltage' and the 'current' appear on the other leg. in my opinion he uses opposing coils but i am not 100% sure on that.
this HV/HF energy is dumped into a big capacitor bank.
now the step-down-part is done with a switching circuit and this transformer-thing that you showed in your post. what i think is, that the primary is a capacitive-coil which is wound in a way that it did not dimish it's source. and this is the key i think.
maybe you do not need this special transformer, because in HF/HV region overunity should take place automatically.
and if we can manage to have the whole structure from first beginning till end in resonance condition would help a lot.
HansKammler posted this 13 October 2025
Good point. Capacitive coil transformer yes. But we need to downtransform hv to low voltage with amperes to drive conventional elmag loads. The Tesla hairpin "u" is a remarkeable peice to drive low R loads like bulbs directly from hv!
Darediamond posted this 18 December 2025
Hello Everyone.
The Don Smith Generator is MAINLY ABOUT one wire output power amplifying transformer. I have been able to replacate it. The Generator is EXTREMLY DANGEROUSLY POWERFUL.
magluvin posted this 21 December 2025
in the small device, with the speaker wire, im in the belief that there is a compression of electrons, back and forth in the open ended windings. like using an avramenko plug diode circuit with a cap connected to just one leg of the open ended hv secondary. i believe that back and forth the electrons in that hv sec wire are being depleted from one end of the wire and compressed to the other end. that would mean current flow, of which would create a magnetic field to induce the inner windings of the output transformer. im not into the Efield ideas as of yet. i believe there is magnetic flux being produced in those open ended speaker wire windings rather than the thoughts of there is only an Efield influencing the output winding. may be simple to test for a magnetic field being produced in the open ended windings. and if the freq of the output of the nst is inline with the resonant freq of the bifi winding, the nst may not experience much of a load.
mags
Jagau posted this 22 December 2025
Yes, it's possible,
but we mustn't forget the primary function of the spark gap, which produces pulses shorter than 10 nanoseconds. This demonstration should produce this effect with minimal stress on the source.
magluvin posted this 22 December 2025
i understand that. just commenting on the one that was claimed in that post to supposedly not have a spatk gap in the circuit.
mags
Darediamond posted this 23 December 2025
The Don Smith Effect Generator Is What You All Should Build. It is straight forward and of 2 stages. Stage one is the Serially Connected windings Voltage Step Up High Frequency Driven Low Voltage Input Transformer With A Primary Winding of Calculated Natural Frequency In View Of it Wire Length which Don Smith talked about Himself. Stage 2 is the Forced Resonance Step Down Transformer that can either be made with Iron Core (50hz/60Hz) or Ferite Core (High Frequency). If you use a 60hz Core, you must use a Combination of calculated capacitor and resistor on it primary leads to bring down the incoming high frequency from the Total OUPTUT wattage Determinant Capacitor Bank back to 60hz. But of you use a Ferrite Core, you just need to add the calculate cap and resistor to tune it to the High frequency your DC Power Damming Caps are charging at and make sure you use a Pi Filter at it output to get a PURE DC that you can use to charge your battery banks and or High Power Inverter or Direct Current Motor etc. Typing sucks; it is not easy at all. So If you need indepth knowledge on How To Build The Don Smith Effect Infinite Output Electric Power Generator, reach me via WhatsApp on +23470 60 578 569
The Don Smith EFFECT GENEERATOR IS THE BEST AND THE MOST POWERFUL OF ALL DON SMITH'S DEVICES!! The reason is because you are allowed to link the secondary to the Primary to get both Forward and Backward E.M.F which thereby makes the transformer a true one wire output Step-Up Trafo WITH SUPER OF SUPER POWERFUL OUTPUT VOLTAGE AND PRSSURE needed to pump a DC Capacitor to produce High Current unlike using a low frequency. The higher the frequency you use to pump a capacitor, the High the output Wattage it would produce. You just need to tune the capacitor to the frequency being used by using a Calculated reaistor to pump it using the formular T = RC. In the attached circuit image is the version that don made before the DON SMITH EFFECT GENERATOR which most of you have been trying to replicate. You need not this anymore!! Go for the last one which He built and called "THE DON SMITH EFFECT" which I have earlier shared it Completed Working Circuit.
What everyone should start building is what Don Smith shows in the attached image.
Jagau posted this 23 December 2025
quoting Darediamond
 So If you need indepth knowledge on How To Build The Don Smith Effect Infinite Output Electric Power Generator.
Hi Darediamond
Did you make a video of this experiment? or a photo with the circuit in operation?
