Zero Transformer
  • 2.5K Views
  • Last Post 18 April 2026
baerndorfer posted this 06 October 2025
In this video i did a replication of the zero transformer setup which is explained by vladimir utkin.
I plan to use this for charging my battteries with solar-power.
if you have questions - just ask.
Jagau posted this 06 October 2025
Hello Baerndorfer, excellent experience.
I just returned from a week of traveling and not much happened on the forum.
Luckily you posted this video here on the forum. It's very interesting. I've watched it a few times.
Yes, I have a question.
Does the frequency change much towards the end when the power drops using the Tesla technique?
This encourages me to continue. You are very careful in your presentation, you are a model.
Hello Jagau,
Since i set the frequency on my halfbridge, it did not change at all. It is fixed.
So, the switching frequency always stays the same.
worldcup posted this 07 October 2025
Nice..
Could you explain pros | cons for battery charging using solar panels (using above zero transformer) in regards with direct solar to battery charging...
One more interesting - 16 Mar 2025 (YT description got more video parts)
baerndorfer posted this 07 October 2025
In my opinion it is best to convert the power from solar panel into a resonating source dipole. this source should be part of a magnetic-system (toroid, E-core, etc) where the extracted energy did not reflect back. we should have an open system where energy from environment can be used to give some extra power (like heat-pumps do). actually i do not know what works best but in my case i will go with this toroid system with a few more components which i will present when my testing is done.
what i know is, that fast switching plays a keyrole in my setup. Jagau and others have done many tests on this subject and i recommend reading it.
since i do no 'ordinary' charging i cannot give an advice here. i would not recommend doing it like everybody does
Jagau posted this 08 October 2025
Hi  worldcup
You will find your answers on this site about the Pros and Cons of Grid-Tied vs. Off-Grid Solar
https://solar.neilkelly.com/blog/pros-cons-grid-tied-off-grid-solar-power/
Here is the Zero transformer of Utkin at the end of the page.
https://samlib.ru/u/utkin_w_m/exper-2.shtml
baerndorfer posted this 08 October 2025
now this is result from power analysis
i use 4W +/-10% for reaching 1,4kVA in the system. this is because the current is highly oszillating but has a low Iavg value. and there is no heat at all. everything is room-temperature.
CH1 is input pulse, CH3 is current on low side of power supply. CH2 is voltage from power supply.
Hi Berndorfer
The first image is difficult to read i cannot zoom in.
If I'm reading correctly, you have an instantaneous power of 4.6 W
and an real (average) power of 3.8 W ??
'Instant' is the last data snapshot. In this run i did 169 iterations and 'Average' is the value we should look at.
have a nice day!
Getza posted this 18 April 2026
Hi, i find another interesting transformer and one youtuber use it in oposite way:
the link to patent is:
https://patentimages.storage.googleapis.com/40/16/0b/9bfe0d154affb8/RU2517378C1.pdf
