My Bunk replication
  • 4.2K Views
  • Last Post 12 May 2026
editor posted this 15 April 2026
Hey everyone!
I've decided to finally give it a go and try to replicate what Bunk has been sharing. Since I already have most of the parts sitting in my workshop, it's mostly just a matter of putting the components together.
My journey goes all the way back to the days of Zilano, Kapanadze, and everything in between. After countless hours and more money spent than I'd care to admit — probably enough that, if I had just added it all up, I could've had free electricity for life and been sipping margaritas on a beach instead. But here I am, and I think everyone here who's been in this rabbit hole for 10, 20 years or more knows exactly what I mean.
One of my last rules I set for myself was that I wouldn't go back into the workshop unless I saw at least 2–3 successful replications of someone's device. Well, clearly I'm about to break that rule.
I created a new thread so I don't clutter the existing Bunk thread, which is already hard enough to follow. Attaching a photo of the simplest device Bunk shared — it was the first thing I found on my shelf. Once I track down the aluminum part, I'll throw it all together and report back on whether it lights up.
Have a nice day or night, e
Hey everyone!
Vasile posted this 15 April 2026
Good for you editor, I too have come to the conclusion that the device you have posted is the simplest bunk has posted about. Unfortunatelly his chaotic behaviour doesn't help much. I will post the schematic in case you do not have it anymore so everyone can see it. Keep in touch.
Kdkinen kurtsvids posted this 15 April 2026
Replying To: Vasile
Great idea with the separate thread Editor ! I love this circuit. I have tried this though, and could not get an output... however I do believe this will work as seen on the videos. I think there may be more to the inside of the core than meets the eye. BTW how do I post images directly under the comment as seen above ?
Fighter posted this 16 April 2026
Replying To: Kdkinen kurtsvids
For inserting images directly in the post you should click the "Insert/Edit Image" button in the editor's toolbar (see the red arrow) and and in the box which will appear click "Upload" then you can browse on your computer for the image you want to insert:
The image will be inserted in the post at the position where your cursor is.
editor posted this 16 April 2026
Vasile, thanks for the scheme. I have ALL the files from the man, so no worries.
Kurt, thanks for signing in as well — it would have been nice if you had shared this info earlier!
To everyone: please share your experience if you've already tried this or any other device, regardless of whether you succeeded or failed.
editor posted this 19 April 2026
I did some tests and use different hv power supplies and loads. Unfortunately this electron pump is not working at this time.
Jagau posted this 09 May 2026
Hello
To insert images, simply read what Fighter wrote three posts before yours.
editor posted this 09 May 2026
Hi All!
Just a quick update. I build the device, try different power supplies.
Unfortunately no juice.
Meanwhile i got some amalgam from the local dentists still waiting for the shaking device. Just scraping some material for some future project.
Fighter posted this 09 May 2026
Quoting:mungam
Hello
Thank you, I will try as presented above
Hi Mungam,
As Jagau pointed out, for images:
For videos there is the buton near (on the right side of the images button) where you can upload videos.
Just keep in mind for videos there is a limit, the video file cannot exceed 500 MB.
If you have any problem uploading images or videos just ask and I'll assist.
editor posted this 10 May 2026
Hi Mungan!
Thanks for the schematic and the video.
Could you please share some photos — or even better, a video — of the device you received yesterday? The YouTube video is very low quality, almost like it’s 30 years old. I’m sure everyone here would be very interested to get a better look at the device you’re describing. Today every device is recording in 4k or better.
hackoa posted this 10 May 2026
Replying To: mungam
Do you have PCB files and would you like to share with users? I see very professional made PCB. I’m not a professional and would like to have it also. Maybe you can open some money account to receive money for this service if you like. Thank you!
