Tom Bearden MEG, Review
  • 631 Views
  • Last Post 17 September 2026
Tommey L Reed posted this 01 September 2026
I built this a year ago, and did a lot of testing. Nothing special was found it the input vs output. I have another idea adding two rotors inbewteen the upper and lower C core with a timing gear to link both rotor.
The rotor run on the input coils and creates a generator effect from both rotors.
Tommey L Reed posted this 07 September 2026
Advenced MEG Modified Version, By Tommey Reed.
Jagau posted this 17 September 2026
Hi Tommy
The problem with Tom Bearden's MEG is that you have to condition a carbon resistor to prove OU
see JL Naudin to create this resistor assembly, see here:
http://jnaudin.free.fr/meg/negres.htm
andy2 posted this 17 September 2026
I think that Naudin's "conditioned resistor" is working similar to nowadays Varistors.
see
http://jnaudin.free.fr/meg/megv21.htm
... a "conditionned" RLoad (100 Kohms, non inductive carbon, 5Watts) or a MOV (Metal Oxide Varistor) is REQUIRED for getting the output datas measured above....
Hi Andy
VDRs and MOVs entered the market in the late 1960s, around 1968.
The main reason JLN preferred a conditionned resistor is that, at high frequencies, a VDR or MOV does not behave like a pure resistor but rather like a capacitor.
JLN was an engineer; he was very familiar with this nuance.
