What is a scalar wave?
  • 1.3K Views
  • Last Post 12 July 2026
baerndorfer posted this 03 July 2026
To be honest i have no idea what a scalar wave is. What should it be? Who describes what? I have read statements all over  the place and it seems that everyone try to describe something which he or she do not understand.
When  we have a room full of dots and  each dot  is separated from the others in a structured way. and when each  dot has a potential, then we can say that this is a potential field or scalar field. so we have x,y,z and time as well. each point can  have its  own  potential value and all together form this field.
now if a motion is transported through this field  and we cut a slice out of it to have a 2d shape, we can explore a 'wave'.
is this the scalar wave, everybody is talking about?
what is it?
is it the situation, that most of us love when a bulp lights up with no voltage on the terminals? is this a scalar-effect? or is it radiant? is scalar maybe radiant?
at this point i am interested in your thougts.
have a nice  day
what is it?
have a nice  day
Jagau posted this 03 July 2026
Scalar waves are used, for example, in the Magnifying Transmitter in which I experiment in Tesla coil..
A Teslian wave, a  longitudinal wave or a scalar wave, travelling wave are all the same thing and have the same definition; only the name differs from one person to another.
It has no magnetic component, only pure potential and cannot be detected by conventional instruments.
They can be created without being able to measure them by placing two coils in opposite phase at same frequency, which produces a pure potential  without current out of phase by 180 degrees, thus the magnetic component is cancelled.
It is the basis of all life in the universe, and its speed is unrelated to that of light. The entire human body and all living matter communicate between cells instantaneously (action at a distance).
This is my humble interpretation.
It would be interesting, as you said, to hear others' opinions on this point.
Jagau posted this 06 July 2026
A visual representation of a scalar, longitudinal, or traveling wave all still the same definition.
 https://ophysics.com/w5.html
Click on the arrow to activate the animation.
and also a standing wave which visually describes very well what it is.
That is why, longitudinal wave, are so difficult to detect but not impossible,  see Dr. Hodowanec website has done extensive research on the subject and usefull rich experiments and circuits.
https://hodowanec.fyi/home/
As for radiant energy, what better way to understand it than by having it defined by Nikola Tesla himself? Note that it is different from longitudinal waves refer to patent 585957
https://teslaresearch.jimdofree.com/radiant-energy
I hope that helped clarify things for you?
baerndorfer posted this 06 July 2026
this  website from dr. hodowanec is great! never heard about that guy. thx for posting
i know these  physics  animation and did some of them for myself to get a better understanding,  but the light is still not fully on.
still learning!
Glad to see you like it, one important document among others is
Resonant Frequency of the Aether
Note that when he uses the term: rhysmonic it means aether to him.
I tested some of these circuits with operational amplifiers, they are functional and his statements are true, the feed true connector capacitor (yellow square) on all his shielded box are very important.
Jagau posted this 08 July 2026
Dark forces don't want you to know all of Gregory Hodowanec's progress; the website has been taken down.
You can find the same documents here:
https://rexresearch1.com/HodowanecRhysmonics/HodowanecRhysmonics.html
until they take that one down too.
Inception posted this 09 July 2026
Wayback Machine hodowanec.fyi/home/
baerndorfer posted this 09 July 2026
If dark forces do not want that i reach your link from here, then they are doing a bad job 😎
Jagau posted this 09 July 2026
The Wayback Machine doesn't save all files, only some.
You're better off with
No files are missing😎
Yes bearndorfer, dark matter is stronger tham dark force
Jagau posted this 12 July 2026
J'ai commencé à construire un détecteur d'ondes gravitationnelles, qui détecte les ondes du même type que les ondes longitudinales (ondes de compression), en suivant les instructions de G. Hodowanec.
Nous verrons, après expérimentation, si je peux détecter l'un ou l'autre, ce qui pourrait être utile pour vérifier la présence de ces soi-disant ondes scalaires dans mes expériences comme celles de Pachuka.
Dixit Gregory Hodowanec, working career with companies such as National Union, RCA and Edo Air as a research and development engineer.
 Détecteurs d'« ondes » gravitationnelles
L'expérience initiale sur les ondes gravitationnelles visait à observer d'éventuels effets d'inertie locaux sur un condensateur pilotant un circuit amplificateur intégré à gain très élevé. Une série de tests a confirmé la faisabilité de cette approche. De nombreux tests ont été réalisés avec un amplificateur audio et un multimètre en sortie. Cependant, lors d'un test utilisant un condensateur blindé de 10 µF, des perturbations ont été constatées, mais aussi d'étranges oscillations persistantes, même après l'arrêt des perturbations ! J'étais fasciné par ces oscillations de basse fréquence (plutôt mélodieuses) et j'avais presque l'impression que l'univers répondait à mes expériences ! Des tests supplémentaires ont prouvé que ces « signaux » étaient extérieurs à mon environnement et qu'ils ne pouvaient être blindés. Cela a conduit au développement de nombreux autres circuits qui ont par la suite démontré que ces signaux n'étaient autres que des ondes scalaires longitudinales générées par l'univers lui-même : une découverte véritablement fortuite !
