Costinbuc's Ideas and Experiments
  • 4.5K Views
  • Last Post 24 March 2024
costinbuc posted this 21 January 2024
I'm starting this thread to present my miscellaneous ideas and experiments.
costinbuc posted this 28 January 2024
Hellow all
In order to do something practical until I will fully understand ZPM model, and many more stuff, I was  thinking to make a replica of  T.Bearden MEG in my view to see if that”ping-pong” is showing.
Layout is like this:
 Available coils below, but I do not have any idea where and which in which place
2,9 mH +/-3% 2,1 Ω = 4 pcs – wire diameter 0.63mm
0,940mH +/-3% 0,500Ω = 4 pcs – wire diameter  1 mm
1,450mH +/-3% 0,470Ω = 2 pcs – wire diameter 1,2 mm
2,100mH +/-3% 0,460Ω = 2 pcs – wire diameter 1,4 mm
Please help !
The only missing part for the moment is permanent magnet
L=68mm W=15mm D=25mm
BR-- CB
Jagau posted this 29 January 2024
Hi Constinbuc
Having already tried both, it is easier to start with Fighter's ZPM than with TB's complex Meg
It's up to you
Jagau posted this 26 February 2024
hi continbuc
we do not see your image
  • YoElMiCrO
costinbuc posted this 26 February 2024
Hi Jagau, I am not skilled in posting.
This is an idea after I saw a russian guy post, wondering why it is nor overcome the 2 points of stalling
The issue was simple
Black lines on fixed magnet is kind of metal that desables the 2 pins above or below it
they should be 2 circular magnets - diametrically polarised and at poles shift  it has to be a metal part that do not magnetize pins above or below
that is the meaning of black lines
Thinking more of this I did post first picture of today in order to use "probably: not stalling rotation to produce some power
that rectangles innside rotating part are metal thst gets magnetized as tehey go around
