  • Last Post 03 September 2024
Mitza84 posted this 19 November 2020
Yes is the same when expanded many small like almost sinusoidal waves .
Mitza
Jagau posted this 19 November 2020
Very well Mitza,
in this forum there is a lot to learn and we share what we know.
You just have to know how to listen, there are some who are able to do it and others not.
Why, because you followed the recommendations.
Several other threads here have some fascinating experiences to try.
There are still other great things to learn in this forum. More to come.
P.S. Another observation, take different waveforms at different point in the circuit with your oscilloscope, you will have a surprise and yes we are in another world.
Hi Jagau i tried to push the circuit with two 1.2v 40mA small bateries from solar led lamp for garden but over night in 12 hours it drop from 2.6v to 1.2v because i wanted to see if is really charging ,on bigger bateries it last for ages from what i can see i put it on 1000 mA batteryes in the morning and it stayed at 2.5 v in 8 hours and is still 2.5v so did not drop but it has a consumption of 0.5mA from what i can measure in blinking mode for me . what i need to know from you is you keep on blinking mode or you push it a bit more to have constant light ? and for you worked on one battery or you use also 2 batteryes in series?  i will let it run with these 1000mA to see how long will last . And if you change the capacitance you can alter the wave by making it longer or shorter .i used 1uF and 2uF It goes well with bouth.
Mitza
Hi mitza84
 First of all I use 2 rechargeable batteries 1.2 volts in series of 300mah for more stability.
The critical point of this setup is the pot adjustment.
When the batteries are charging at the beginning the 2 leds flash, the more the batteries charge you will then notice a slowing of the flashing until only one led flashes weakly and the other is stable. As you have the correct waveform at this stage your batteries will be fully charged.
Normally on a different setup other than that one, the batteries only last about 4 days according to my calculations.
Mitza84 posted this 20 November 2020
Hi Jagau ,yes you are right this is indid a very long runner .i will keep under observation longer time to see what happen .thank you for the infos. i hope i can make it on capacitors that would be really cool .but maybe you do it faster .
Mitza
Jagau posted this 09 December 2020
Hi Mitz
I tried it with a capacitor of the same capacity as a battery that I use and it lasts about 2 days.
A capacitor has no chemicals like a battery.
It is a passive component i.e. it cannot produce ions which produce the recharge of a battery by changing the chemical state of its electrodes. It cannot be discharge and charged at the same time with low voltage.
We can clearly see in Akula's schematics that he uses another process for recharging a capacitor at same time it is used. In his diagrams as I understand it, he uses the capacitor in a first phase, it is the discharge and in a second phase he recharges the capacitor. Thus we produce the charge and discharge in 2 phases
These are the type of experience that I am reproducing now.
UndisclosedMember posted this 13 December 2020
Hi Mitz
Jagau, hi, do you remember me? Hi again!! Will not write too much, but I have something to answer. As I born in USSR, I speak russian. Akula clearly says in one of his videos (from his Youtube's channel), that you should use high voltage capacitors, above 50v, he says that 63v are good enough, and those are made differently. He says, it is for catch high voltage peaks better (or something like that).  Don't know if it true or not, but I must to say it.
Hope you success running Nekvadrat's circuit on some capacitor (or supercapacitor). I am not expert, but personally, I don't recommend you to use supercapacitors, because of vloss (leak). I have some good flashlights on 10000uF-25v (Jackcon), sharges instantly and works with good bright light for 5 minutes (well it lasts more but light dims) (no overunity or something like that). I did tests some caps of this type, and those aren't equal. Those from Jackcon have very low leackage, while some of NONAME/NOBRAND chinese capacitors of this capacitance have much more leakage while my Jackcon holds charge for days and has very small leaks. My experience with supercapacitors is, when you chare them until it draws no mA and disconnect them, you instantly will lose a lot of voltage. I recommend to testing with good brand capacitors, and well, if it higher voltage, the better.
Jagau posted this 13 December 2020
Yes I remember you Vita cell we met on this site in russia
I have already entered the web address of this site at the beginning of this thread.
Ok thanks for the good advice, I take them all.
For supercapacitor, you are right they are not very efficient and especially they only work between low voltage.
Precisely the high voltage capacitors seem more efficient, always in search mode.
My greetings
хорошего дня, твой английский хороший и ясный
Translation (added by Fighter):
have a nice day, your English is good and clear
Here is some explanation about "добротность" (looks like is "Q factor" in english) of capacitors. He also do some tests. https://en.wikipedia.org/wiki/Q_factor
At 14:42 he concludes: "when we have a capacitor with so big volts hold/reserve, the capacitor's Q factor increases"
At 15:59 he says: "his (capacitor's) Q-fac looks like it is lower, but it is lower because we charged it almost near to his nominal electric potential (volts)."
Here is Akula's explanation at 0: 33:
Akula says: "Those capacitors that can perceive/catch/capture backward high voltage drop/peak(*оэдс), only high voltage ones are valid. So, 400v, 60v capacitors. Right now I have 63v one and it works fine. For selfrunning (catch voltage peak) those are better. Are better because those aren't paper made, those have bigger distance/space between plates. Those are capable to catch and charge with high voltage peak that are up to 50-60v, while those don't create additional load. All 16-35v capacitors are weak for this, those above 50v catch this backward peak better."
эдс = it is electromotive force
https://en.wikipedia.org/wiki/Electromotive_force
оэдс = not sure how to translate it in english, but it is backward electromotive force drop, looks like one from autoinduction.
Very interesting, thank you Vital cell I am going to study seriously.
I love it a lot, it gives me ideas
Tom Bearden called this massless current transfer
