Is an automatic system possible?
  • 5.1K Views
  • Last Post 18 December 2024
Atti posted this 30 April 2022
Welcome everyone!
We have a circuit with an on and off power source.
Now imagine a black box with a structure that provides infinite energy.
So we only have one source of energy coming out.
Can this exist?
The question is what might be in the black box.
Self-feeding structure.
What could this structure be? Can such a structure exist? How can you produce energy? What is energy? What is the mechanism that works continuously (or until exhaustion)? Is it moving or not?
We are always looking for answers to this.
Some people claim to have found the mechanism. There are two kinds of human attitudes.
Some say:
-I show some drawings or some theories. If you can’t do it you are stupid or just TROLL.
-or I'll show you a shot of the structure (maybe some nonsensical drawings) but buy it below. For money.
Yet human curiosity drills our side there.
The little devil sits on our shoulders and is constantly poking with his fork.
That's where the thought rides within us.
In vain. The desire for knowledge has always been the driving force behind man.
Reality doesn't matter just experience.
But what makes it work? Does it really work at all?
I will now outline a series of events. And that’s just an excerpt from my humble experience so far.
I don’t want to line up like quite a few “inventors”.
That is, to say something. It shows a few frames or videos, and then everyone finds out the rest on their own.
Then if it fails, blame everyone.
Let's say it's TROLL.
Let's just talk about everything, not the point.
He tries to show the point but also falsely.
So.
Since I am not an inventor or an over-trained engineer and I have nothing specific, I will only share a few basic thoughts with you.
Full of mistakes, but full of possibilities!
Possibilities that have been discovered by others besides me. This is just a series of thoughts that others have already done during the experiments.
I did some of them again. There is a phenomenon.
-The first and simplest version:
2:01:30 we can see a higher peak reflected in the incoming sine wave. If set correctly, this will reduce the input energy.
I have processed these phenomena. The E.r. shown in my videos.
-Motion of magnetic fields under partial guidance:
Directed primary magnetic field
Directed secondary magnetic field
Directed permanent magnetic field
Iron fuxus
Coil flux (scattered) discrimination.
Closure of magnetic paths by the shortest path.
Resonance.
Reflection (back to source field)
Continuous circular motion.
Atti posted this 15 December 2022
For a few thoughts, I will continue the replication of Fighter here.
I examined several types of transformers. A small phenomenon can be detected with some, but the Amcc behaved best.
I rewound the entire Amcc20 transformer to rule out the possibility of failure. With the same thread numbers but insulated per line.
The result is the same. But everything is all right.
I have now done the experiment with a battery. The power supply voltage is 32V, the control works from 18V. So NO MAINS VOLTAGE! (This was Itsu's problem)
The oscilloscope, on the other hand, has a network ground. (there is nothing wrong with my electrical network! Residual-current device is 30mA and does not disconnect)
I use this as grounding. But there could be a separate ground probe, whatever.
As you can see, the neon lamp lights up at the common point of L1 and L2 without grounding. You have to find the right setting. The controller placed next to the battery is a good help in the settings. It is a ferrite rod with a few threads and a parallel LED connection. Just like Fighter used. I also added a 50 yA Deprez instrument.
The radiation is clearly visible at certain points. (antenna? transmitter or receiver?) It is amplified by grounding.
Since the core is small, it cannot be heavily loaded. But the effect is still there. It does not go down to zero in all cases.
At this point, I'm not even looking for that, but the current-reducing effect. Also, the current directed back to the battery, as Jagau suggested.
So. If in the correct setting I place the grounding at the common point of L1 and L2, it can be seen that the high voltage appears almost everywhere! (at the end of the video I accidentally touched it and shook it well)
In another setup (I won't show this yet because it's uncertain), a very strange resonance appeared when supplemented with a capacitor. (resonance in resonance) At first I thought that the 50Hz frequency of the network was displayed. But not!
You can see the frequency on the 100 ohm resistor. (output voltage is then displayed)
So far, this setup has only received a pulse, not a variable voltage.
Now consider the MEG generator.
-L1 -L2 common point
- Let's look at the waveforms and voltages given in the patent.
- Let's think about the secondary coils. Let's examine the connections.
-Bearden talks about dead current several times
- what happens if the parasitic capacitance is added to the secondary coils
If the secondary winding becomes the primary winding at some point, it will charge back into the power supply. This also appears in the shape of the current.
I have already experienced this phenomenon in a different arrangement. (see based on previous videos)
Jagau posted this 15 December 2022
Very interesting effect that you found there Atti,
bigmotherwhale posted this 15 December 2022
I found the same sort of effect in my first experiments.
Atti posted this 25 January 2023
Let's look at another test.
This is not the classic ZPM. But let's look at the similarities. We see similarities in other circuits.
You don't need to load now.
Here, the primary and secondary windings are selected separately. Therefore, the primary circuit and the secondary circuit must be interpreted separately.
In this arrangement, the primary winding is not connected in accordance with the inductance and excitation, but oppositely. So the induced magnetic field repel each other. (L1-L2 NS-SN can be found in the drawing) Thus, there is no induced voltage in a symmetrical secondary winding.
The inductance here is almost zero.
There is some inductance due to loose coupling only.
Although we know well that every wire has inductance, so it cannot be absolutely zero. Even if it has the same direction as the magnetic polarity. Especially if the frequency increases.
Here, the coils have mutually repelling magnetic fields.
The question is, are there any advantages to mutually repelling magnets placed on a common iron core? Any inductance? Any induced voltage?
- Differentiate the primary excitation flux (magnetic field)
-Distinguish between the flux excited by the secondary current (magnetic field)
- Differentiate between the flux enclosed in the common iron core (magnetic field)
Let's see the reaction due to the field excited by the secondary current with respect to the primary.
- Although I have already written it, I will note it again: this is the same phenomenon with Amcc20 or Amcc320 or CRT ferrite or flyback ferrite. (visible on the workbench)
-The recharge is less, but not negligible. It depends on the setting. It depends on the fill factor rather than the frequency.
-The switching mosfet is cold all the time.
- The phenomenon also exists when the earthing is disconnected. So there is no need for earthing in this case.
- This is also the case with batteries.
An impulse and a reaction. The size of the recharge is the question.
Jagau posted this 25 January 2023
Wonderful you are an artist Atti
beautyfull
Fighter posted this 25 January 2023
beautyfull
I agree ! ☺️
YoElMiCrO posted this 25 January 2023
Yes, I agree.
Atti apart from being electronic
he is also an electronic artist.
What a job, I am 100.
realco posted this 25 January 2023
Madre de dios!!!!!
All my respects Atti!
SonOfLuck posted this 25 January 2023
+ 1 point for using hungarian swearing.
Terjeszd az igét
Atti posted this 26 January 2023
It was the second time that the electricity "stung" me. Suddenly, that ugly sentence came out of my mouth. This is really not correct. I could have cut that out. After that, I will limit the video.
As for the "wire Atti". Sometimes it doesn't hurt to try to be creative. This genre may require this as well.
But what did we see in the video?
