Joel Lagace's Quantum Power Cell
  • 6.1K Views
Fighter posted this 21 March 2024
Remember the Water-Based Long-Running Device ? It worked continuously for 2 years until the Zinc plate corroded but if I replace the plate it could work again for another 2 years.
Its only inconveniences were:
  1. The water needed to be replenished at every few weeks because of the natural phenomenon of water evaporation;
  2. Altough the copper mesh was not affected by water corrosion (as normally should happen), the zinc plate was slowly corroded and needs to be replaced after about two years.
Well, seems there is possible to replace the water with a solid-state material which will resolve the two inconveniences specified above.
The solution is a polymer named Polyethylene Glycol (PEG). As you can read here:
Although not yet in commercial production, many groups around the globe are engaged in research on solid polymer electrolytes involving PEG, with the aim of improving their properties, and in permitting their use in batteries, electro-chromic display systems, and other products in the future.
But as Joel Lagace discovered, it can be also used for building its device he named Quantum Power Cell which is providing low-current but constant electricity.
More specific Joel used Polyethylene Glycol (PEG) 3350 which is used in some pharmaceutical products. He used PEG 3350 from Relaxa but there are similar products made by other companies.
Theoretically the device should work forever without maintenance because after the preparation PEG 3350 becomes solid and there should not be any corrosion/degradation effect on the anode and cathode made from carbon felt. But this could only be verified by running the cell for a long time.
Altough the device is experimental it can keep a LED on permanently and provide enough current to power a Joule-Thief or a very small electrical motor.
Joel says that more current can be provided by moving the anode and cathode as close as possible to each other so the output of the device could become higher.
Here is how the solid-state PEG 3350 is prepared and placed in the cell:
And here are some demonstrations on what the cell can do even if it's in a early stage (see the anodes and cathodes are not that close to each other):
Joel is estimating that many of these cells put together could power a LED light bulb for about 20 minutes through some capacitors then they need some time to recharge again.
Of course I see no problem in scaling up this cell (more PEG 3350, bigger anode and cathode) so it can provide more power.
And here is a self-charging demonstration using a small electrical motor as load:
I intend to build one of these quantum cells as a side project. I'm interested to check if there is any degradation of the PEG 3350, anode or cathode when the cell is running a long time with a load.
If there is no degradation that means the cell can be an alternative to Melnichenko's/Akula's eternal flashlight. But that remains to be verified in time.
As this device have no input it's obviously overunity so I added the "Beyond-Unity" tag to it.
Fighter posted this 28 March 2024
And the confirmation that the cell could work with similar metals:
It's true, not that efficient than when using dissimilar metals but it still works.
This means something important: this is something very different than any ordinary galvanic device, by using similar metals there will be no corrosion/degradation process on electrodes in time.
hitsfm posted this 29 March 2024
I suspect that this is working perhaps in part because its the solid state electrolyte mix acting as the second dissilmar metal. Let me try and explain, That PEG mix is the active engreedent but there is other stuff in it as well and with the addition of the sports electrolyte ( the blue stuff) if you read the back you get all these added minerals because of its sports drink. Perhaps those minerals are acting as an internal electrode and the second tin is just acting as an electrical conductor like a wire. But that does not answer in complete form why it works with only tin and not 2 carbon felts if that was the case. Only time will tell.
What I do know for sure they have the self charging electret properties of the peg without conditioning. Just leave it alone over night and by morning it accumulates a stable charge. My Live wire meter actualy detects a field with I put the probe near the cell. It only lights up to orange but still intersting! And as I noted can be conditioned to exploit this feature some more.
Inception posted this 30 March 2024
This is the equivalent to Miralax which is manufactured by Bayer. There are no extra ingredients added to the PEG 3350.
AlteredUnity posted this 30 March 2024
I ordered Padagis brand that has no additives as well. Also have copper, aluminum, nickle, zinc, tin, iron, and carbon plates to cut, and magnesium on the way....just need to set my cnc machine up. Hopefully will find time to make some configurations happen. soon.
Fighter posted this 30 March 2024
I propose to create our own replication threads in the Replications category so we can keep this thread clean.
We'll have here only updates about Joel's experiments, his posts when he wants to come with updates and eventually our questions for him.
I think it's better this way so we don't mix the information about different experiments in this single thread.
I created my thread here: Fighter's Quantum Power Cell Replication.
Fighter posted this 31 March 2024
After one week of running the voltages of Joel's quantum cells are constant, including the one with similar metal (tinfoil).
Also no signs of corrosion on the electrodes.
Fighter posted this 03 April 2024
Something very strange in 3 of Joel's quantum cells: if a reverse pulse is sent to them they respond back with a bigger pulse (obviously more energy than the pulse we sent):
Very interesting, this is a very clear process of energy amplification ! šŸ™‚
Seems this video is made to show this phenomenon to John Hutchison.
Jagau posted this 04 April 2024
Hi Fighter
One of my researches gives similar behavior on a capacitive circuit. With just one very short pulse, Aether reacts strongly to abrupt changes. Everything happens outside the component as C.P. Steinmeitz said. The electrostatic or dielectric field.
Fighter posted this 05 April 2024
Absolutely, Jagau, I agree.
All our overunity devices are interacting and gathering energy from the Zero-Point / Aether / Quantum field (how we name it is not really important). That's the source of energy which make them go Beyond-Unity.
In the case of these quantum cells the PEG 3350 is one of what we call "metamaterials".
From one of my previous posts here:
Just adding here a fragment from one of my posts I've made in February 2023:
My prediction is: the most advanced Beyond-Unity devices of the future will not need input energy at all. And the secret of building those machines are the Metamaterials - artificial materials engineered to have specific properties not found anywhere in nature. For our specific field of research that would mean metamaterials designed to interact directly with the zero-point quantum fluctuations, get their energy and convert it to the kind of energy we gonna need - thermal, electrical or even mechanical energy.
For now this cell is a low-power output device but it shows what's possible in that direction.
Maybe you guys don't agree with me or have different opinions (which is perfectly fine) but you probably noticed that personally I'm also interested for a very long time by the UFO phenomenon and I'm watching closely what is currently happening with the disclosure process and the reverse-engineering since 1940s of some of the alien tech from crashed UFOs.
From my long-time research and based on multiple sources of information I know that those crafts are also using metamaterials for their energy and propulsion systems. Because the technology they're using is so far advanced than ours we cannot replicate those metamaterials but we observed what they do and we recently started to understand and to build our versions of those metamaterials. Obviously our replications are not that efficient, far less advanced but we've been inspired by the foreign tech and we've seen what's possible.
For anyone interested here is just an article in the press but believe me the info there is just a small piece from the tip of a very old and very big "iceberg".
A few phrases from the article related to the subject of my post:
...layered magnesium and bismuth alloys...
...the material could become a “lifting body” with the right amount of electromagnetic static and certain RF frequency. These are undoubtedly the same materials mentioned by DeLonge on his Joe Rogan interview where he stated, “if you hit it with enough terahertz, it’ll float.”
Of course this metamaterial is related the propulsion system not to the energy system but it's just an example of what I'm talking about.
Fighter posted this 06 April 2024
Joel just published on his YouTube channel here a document containing a summary of his research and the conclusions of his tests with his quantum power cells.
This is a image from the document showing a cell powering one LED:
Just a proof that these cells are capable to do what Melnichenko's/Akula's eternal flashlight devices can do.
So if you want an ethernal device in your research lab always reminding to you what's possible you can build one of these cells or Jagau's Micro-Generator - another example of an ethernal device gathering energy from the Zero-Point field.
For convenience, safety and later references I'm attaching the document to this post so we can have it available on our site.
Thank you Joel for your research and your contributions in the battles we all are fighting for a better future for the humankind !
