Micro generator
  • 7K Views
  • Last Post 01 December 2025
Jagau posted this 09 May 2022
Energy Harvesting with Electro Magnetic Micro Generator
Energy Harvesting (EH) from human or environmental sources has proven to be an effective alternative or complement for battery charging or other uses.
 As light, thermal, mechanical and RF are major sources in EH and among them, mechanical energy from wind, waves, vibrations, etc. is commonly existed in our daily life.
In this new thread the energy will be harvested by using micro generators. This research project addresses the development of a unique EH circuit capable of fulfilling our needs.
more to come
Spark2
HansKammler posted this 23 September 2025
Jagau one question: to extend the power of your micro generator did you maybe think about it to use the Pulse from the 10uF Cap to pulse your triple 80uH Coilcapacitor project ?
https://beyondunity.org/thread/non-linear-resonance/
Page 3:
could you test this , as I´m waiting for parts...
Jagau posted this 24 September 2025
The micro generator isn't powerful enough to power the 3 coils circuit. ugen produces only 0.5 micro-joules per flash (C Vsquare / 2 X DTC)
while the 3 coils circuit requires 30 milli-joules, (3 V X .010ma x 1 sec )
you can play with the resistive voltage divider to vary the flash speed like Fighter did.
Happy experimenting.
 just a precision in 3 coils circuit coils are in millihenry = 0.080H
not in uH 0.00008H like you wrote.
HansKammler posted this 25 September 2025
ok understand. yes 80milliHenry ! thank you. How much Joule we need to "ping" the 3 coiler ? who to change your Harvester to give the needed energy ? change the 10uF to lets say 100uF ?
sorry for interferring the thread. I just answers Baerndorfer.
Jagau posted this 25 September 2025
Replying to hanskammler
I also change your Harvester micro generator with this
I don't understand what you're saying. My micro-generator doesn't use any batteries; it's powered by ambient energy.
Your proposal uses a large battery?
No possible comparison.
HansKammler posted this 26 September 2025
forget the battery. instead I had the 4x uf4007 and a 10uF cap connected. I showed you this only for the avalanche switch effekt. the base is not connected and when U>15.8 my bc547 will close briefly and an imense Flash from led occured.
Getza posted this 29 November 2025
Found this interesting device:
Jagau posted this 30 November 2025
Hi Getza
Yes, interesting.
The model you're showing in YT is an air-driven pump; the model I designed uses two differential ground points..
Jagau posted this 01 December 2025
Energy Intake Valve (E.I.V.
PLATE [ D ] of CAPACITOR, WITH A PREDETERMINED VOLTAGE PLACED UPON IT, CAUSES PLATE [ E ] of CAPACITOR TO DUPLICATE -- FROM THE AMBIENT / EARTH GROUNDING -- THE ENERGY [in the form of Voltage / Potential] PRESENT AT [ D ]. WITH AN INPUT DIODE PLACED AT [ C ] AND AN OUTPUT DIODE PLACED AT [ B ], THE ENERGY PRESENT ON [ E ] FLOWS THROUGH A TRANSFORMER INTO AN EARTH GROUNDING. USEFUL ENERGY IS OBTAINED FROM THE TRANSFORMER. DONALD L. SMITH, 14 FEBRUARY, 2004.
CAPACITOR FUNCTIONS
Don Smith wrote:
Two main types of capacitors are found in widespread use; namely, regular ["standard", "conventional"] and electrolytic. Super Capacitors are also becoming more generally available. A Capacitor is a blocking device. The charge is placed on one side only. The other side draws an equal amount of Energy from the Ambient Background.
The Capacitor is an Energy Pump.
The second side captures ambient energy and will -- on its own -- maintain its charge, even though there is energy passing through the outlet [i.e., _flowing through_ this second plate, to go feed the load]. The beauty of this is that, when used with a diode, and / or a diode bridge -- which are one-way devices -- you have an Energy Pump with unlimited output. The reason the second side can perform this unlimited output pumping function is that it feeds from the Ambient. By arranging the diodes, you can get negative or positive output. Positive output will die a heat death [i.e., will be hobbled by resistance, and won't be able to convey energy very far] whereas the negative will run cool. The only limit on the output is the capacitor size. New shoe-box sized super capacitors are rated, as single units, at greater than 400 Farads, and deliver 400,000 Watts of energy storage.
The Device does not deplete if only the output side is used. Since this action has not been named, I get to name it. Further, if one leg of a light emitting diode is attached to the output side capacitor plate, the LED will provide an effective visual observation of the DSE. The main output side should be a diode passing through to the point of use or load. Another phenomenon is observable; namely, a cooling effect, as seen in the heat exchange modules."The capacitor transformer opens the door of an endless source of useful energy".
This why i used two different grounds point. in my micro generator with capacitor is an energy Pump , proof is there.
