RIGOL MSO5000 Live Monitor (Hacked FW Compatible)
  • 3.8K Views
  • Last Post 27 August 2025
baerndorfer posted this 12 July 2025
Hi all,
because i was not very satisfied with Web-View from Rigol for my MSO5000 i build my own one.
This tool provides a live view and SCPI-based data extraction from a **Rigol MSO5000** oscilloscope with **hacked firmware** via VNC and VISA (SCPI) interfaces.
The script displays:
- Live screenshots from the oscilloscope (via VNC)
- Channel information including coupling, bandwidth, scale, offset, and probe settings
- Trigger and timebase settings
- Raw waveform statistics (Vpp, Vavg, Vrms) for up to 4 channels
- A scrollable debug log for diagnostics
## Requirements
This script is written in Python 3 and depends on the following libraries:
| Library    | Purpose                            |
| `tkinter`  | GUI interface                      |
| `Pillow`   | Image processing for screenshots   |
| `numpy`    | Numerical processing of waveforms  |
| `pyvisa`   | SCPI communication over TCP/IP     |
| `vncdo`    | VNC client to capture screen image |
### Install dependencies
Make sure you have Python 3 installed, then:
```bash
sudo apt install python3-tk python3-pip
pip3 install pillow numpy pyvisa
sudo apt install vncdo
> Note: On Debian/Ubuntu systems, `vncdo` is often available as a package. If not, install it via `pip install vncdo`.
##How to Use
```bash
python3 rigol_vnc_liveview4.py
You will be prompted in the terminal to enter the IP address of your RIGOL MSO5000.
Make sure:
- The oscilloscope is on the same network.
- VNC is enabled on the oscilloscope.
- The oscilloscope responds to SCPI commands over TCP/IP.
##Hacked Firmware Notice
This script is optimized to **avoid crashing or hanging** when used with unofficial / hacked firmware:
- Timeouts are reduced
- Some known problematic SCPI queries are skipped or blacklisted after failure
##Screenshot Path
By default, screenshots are saved temporarily at:
/tmp/oszi_screenshot.png
##Customization
You can adjust these in the script:
- `INTERVALL_BILD`: How often to update the screenshot (seconds)
- `INTERVALL_SCPI`: How often to fetch SCPI data (seconds)
- `WAV_POINTS`: Number of waveform points to request per channel
##License
This project is for **personal use only**. Use at your own risk. Not affiliated with Rigol Technologies.
Hi all,
## Requirements
| Library    | Purpose                            |
```bash
##How to Use
```bash
Make sure:
##Screenshot Path
##Customization
##License
Jagau posted this 13 July 2025
Hello Baern,
how do we open this file?
Fighter posted this 13 July 2025
That's a Python script. I'm not coding in Python but I know in order to run it you should install Python on your computer:
https://www.python.org/downloads/
To see its content you can open it in Notepad.
baerndorfer posted this 13 July 2025
i made an update, so that we can extract channel-data from scope.
Ok thank you both
to be honest i do not know how to install python on windows. i guess you use windows. but it should not be complicated. when you have it on your machine you will need the libraries which i noted in first post. when all is running you should open a terminal and start the script by typing 'python3 scriptname.py' and it should work. if it don't run you will get error messages which will tell you what libs are missing.
the last version includes 4 tabs with lots of data..
happy coding
maybe you want to unlock your MSO5000 for some good reason you can find information at eevblog
@Fighter: i do not know if you like to have this link on server. simply delete it if you have to.
Jagau posted this 14 July 2025
Hi Baern
This is what I currently have on my oscilloscope.
Same as yours.
As for programming, I'm not knowledgeable enough to play around with it. I'll just stick to the first result, which is excellent, as in the photo. Thanks anyway.
baerndorfer posted this 14 July 2025
you made it which is excellent! 😀
the new version can handle multiple oszilloscopes and we can do a Long-Time-Measurement to get data out.
it works for a single channel and i try to make it work for all channels simultaniously which is difficult because of scpi and tcp limits.
when there are no more bugs i will upload this new version.
thx for testing!
Fighter posted this 14 July 2025
Do not worry, we don't have this kind of restrictions here, this is our team's site.
The only links which we shouldn't post are links which could be harmful to our members and our visitors like pointing to spam, viruses, trojans, etc.
It's absolutely not the case here, the link is on subject and pointing to a technical site.
AlteredUnity posted this 14 July 2025
Nice job baerndorfer! I've been testing a few script for simple core parameters, can you make it collect math channels data too? It would make things a lot easier then doing math by script finding switching spots for segmented integration.....
i decide to published this thing to github. since there are many MSO5000 users out there with hacked hardware it makes sense somehow.
https://github.com/ariDev1/MSO5000_liveview
if math channels are working (finding a way out via scpi) on hacked MSO5000 i will integrate them. good idea
