Water-Based Long-Running Device
  • 5.4K Views
  • Last Post 25 March 2024
Fighter posted this 22 May 2022
This is the imported thread (from our secondary forum) about the water-based long-running device which is running continuously since 4th March 2021:
As this thread is public, in order to protect the identity of the members I'll use for their posts a member placeholder named UndisclosedMember.
UndisclosedMember posted this 30 June 2021
hi UndisclosedMember - it seems that the archive is locked for me.
Hi UndisclosedMember
correction made, clik on this link
drive.google.com/file/d/1c0s0Ksp-1dltwNWkkHwDmZs8r1gflWcz/view?usp=sharing
tell me if it works for you
UndisclosedMember posted this 01 July 2021
now it works thx!!
Fighter posted this 01 July 2021
It works for me too, I just downloaded the pdf and I will read it when I find some time. If you have other related files please share them, thank you UndisclosedMember !
@ Fighter.
Such cores are used in the
lighters for kitchens, it is an oscillator
high voltage that runs on a 1.5V battery.
I hope it helps you.
@ UndisclosedMember.
Perform an experiment with the magnets and
I can say that the internal resistance is very high.
I haven't experimented yet with the one that Fighter shared,
at the shortest possible time I do it, because it is very interesting.
Thank you for sharing with both of you.
UndisclosedMember, thank you, it absolutely helps me, I'll check on those lighters.
Fighter posted this 02 July 2021
I just want to clarify something. By presenting this device I don't intend to derail anyone from the projects they're currently working on.
I just want to show what's possible by presenting a long-time low-power runner which any scientist of the current scientific establishment will tell you it's not possible.
Just keep in mind this tech will never be able to power your house.
But if it can be made more solid-state (so to speak) could provide for example a flashlight which could run 24/7 for about one year or more. Or any other low-power device you can think of. Which I think is not that bad.
Having a device like this running permanently in your home could provide inspiration and could help you in breaking that mental barrier they implanted in your mind which tells you what's possible and what's not possible according to the current scientific establishment.
UndisclosedMember posted this 02 July 2021
it works but in my case the paper has to be wett.
is this an ordinary galvanic process?
i build 2 cells - one cell has exactly 3V like Nigel said.
put 2 in series and did a stabilisation with electrolytic cap (6,3V/1000uF).
the voltage under load is 2,45V - LED is 10mm
regards!
Very nice !
Yes, the paper needs to be wet so it can facilitate the migration of ions from copper to the zinc.
In my opinion this is not an ordinary galvanic process. If it would be an ordinary galvanic process the cathode (zinc) would be covered very soon with a layer of copper and within a very limited time the cell would stop working because we'll basically not have different metals anymore, we will have copper and zinc covered in a layer of copper (so the device will see it as copper).
I still don't understand the role of magnet in Nigel's cell as in the device I have there is no magnet on the copper mesh.
But it must have its role in Nigel's cell. For sure it's related to the fact that copper and zinc are diamagnetic as UndisclosedMember said.
Hello UndisclosedMember, it is nice to see your cells, it is very successful.
Indeed the paper must be wet but with ethyl alcohol which is easily found in pharmacies it works longer and we have a more stable and strong voltage.
@fighter,
the magnets, I believe, are above all for, facilitating the assembly, no need for a plastic case and no need for elastic to hold the assembly. Niguel speaks in his document that this has an additional ionic effect, but I have not noticed this effect to date. But this ionic shift remains to be verified
P.S.
  Niguel starts from the fact that the mass of electrons moves faster in some metals than in others, which is why he uses this has the advantage of the quantum battery.
Another very very important fact is that he discovered a very simple thing that nobody thought of.
The SOUTH side of a magnet is more powerful than the NORTH side when they are in repulsion mode.
