Water-Based Long-Running Device
  • 5.9K Views
  • Last Post 25 March 2024
Fighter posted this 22 May 2022
This is the imported thread (from our secondary forum) about the water-based long-running device which is running continuously since 4th March 2021:
As this thread is public, in order to protect the identity of the members I'll use for their posts a member placeholder named UndisclosedMember.
UndisclosedMember posted this 03 July 2021
Here is the visual proof of Niguel:
The 2 magnets on the left are in a tube with the SOUTH  in opposition
The 2 magnets on the right with the NORTH in opposition
if we give a value on 5 the SOUTH is 3/5 and the NORTH 2/5
Did you know it?
i tried it with my magnets and this did not work for me. i can measure the same distance no matter which side from magnet i use. maybe there are magnets out there which are capable of doing that. regards!
Fighter posted this 29 August 2021
Just a small update.
The device is going strong for almost 6 months now (will be full 6 months on 4th September) šŸ™‚
The light is as strong as in the beginning. I just completed the water level with a few water drops once at every approximately 6 weeks (water is evaporating naturally and extremely slowly and its water level needs to be kept at about one centimeter water height).
There is some white oxide at the edges of the zinc plate but looking at the way it's progressing now I think the device will complete the one year endurance test, maybe will run more than a year.
About replication, I bought some copper fabric from Amazon UK and I received it (it came from Europe):
www.amazon.co.uk/gp/product/B08HXXP47R/
But the pure Zinc plates I ordered also from Amazon are still on the way because they are actually coming from China:
www.amazon.co.uk/gp/product/B08MCHXBGC/
Fighter posted this 30 September 2021
And another update, I performed the maintenance for the device as the lights became a bit lower because of that zinc oxide I was talking about.
So I dissolved a spoon of lemon salt in 200 ml of water and filled the recipient. The water looked like it was boiling while the white zinc oxide started to dissolve.
During the process the lights became very strong, much stronger than during the normal functioning of the device. I kept it like that about 5 minutes as there was considerable zinc oxide
quantity at the edges of the zinc plate. So I kept it much more than 1 minute as specified in the user manual, hoping to clean as much as possible from that oxide.
This is how it looks after maintenance, there is still some white oxide but didn't wanted to exaggerate and keep the cleaning process more:
And after the maintenance I cleaned with fresh water the primary power source and the lights became stronger as usually:
During the maintenance I checked the thickness of the zinc plate, it's still thick.
Based on that and considering the fact that it's running for almost 7 months now, I estimate that the device will run much more than just one year.
UndisclosedMember posted this 29 January 2022
Hello
Dale Pond The Basic Principles Of SVP Sympathetic Vibratory Physic
s
Fighter posted this 23 March 2022
On 4th March the device completed one year of continuously self-running.
As today I needed to put a few water drops in it to complete the water level, I've made a few photos and one video with the device running:
I checked the thickness of the zinc sheet, I estimate the device could continue to run for at least another 6 months.
Few conclusions after one year of observations.
I said it's nothing exotic about the device, I need to correct my affirmation as there are some anomalies:
1. The device is not a simple chemical-reaction way to provide the initial energy in the primary block, there is more: I observed that the power of the light is significantly stronger in the morning within the 2-3 hours before the sun is raising at horizon; the reason is unknown, maybe in those 2-3 hours there is more energy coming to Earth and it is capable to somehow capture it ? maybe the neutrinos we talked about in other discussions ? But why only in those 2-3 hours before the sun is raising at the horizon ? after sun is above horizon the light seems to get back to normal (as much as I can observe when there is also daylight);
2. The very fine mesh made of copper is not oxidized at all; there is some white zinc oxide on it coming from the zinc sheet but other than that there is no copper oxidation, you know the copper oxide is greenish; copper submerged in water will always get a layer of green copper oxide in a very short time but this process is not present in the device; considering how thin the copper is in the copper mesh (you can see it in photos) I was initially thinking the copper mesh will be completely oxidized within 1-2 months; it didn't happened and the copper mesh is 100% copper-oxide free; the reason is also unknown.
I don't know if Akula's lantern is running forever but if it's not I think this device is a serious competitor for Akula's lantern. Its only disadvantage is the fact that it's using water which is not ideal for solid-state devices but it's not consuming the water, the reason I need to put a few drops of water in it at 1-2 months intervals is because the water is naturally evaporating in time.
Considering its behavior before the sun is about to rise maybe the water is using also as a medium to gather additional energy coming to Earth in that 2-3 hours interval.
Why I say that ? It's because I saw some researchers saying that in the well-know "Casimir effect" the power is much stronger if the two metal plates are submerged in water.
This is not verified as I didn't found any experiment proving that affirmation but if it's true then water could be a medium which could amplify the effect in devices capturing zero-point field energy.
For now it's just a speculation of course...
As I'm very busy at work right now I don't have free time but I intend to find ways to take measurements from the device, more specific the voltage and current provided
by the primary source (the module submerged in water) then frequency and the waveform received from the Joule-Thief module to the LEDs.
As I specified the wires and the transistor are encapsulated in glue but I'll try to reach those wires and take the measurements without damaging the device.
  • Getza
UndisclosedMember posted this 27 March 2022
Hi, Fighter, awesome, it is a very good device. Taking measurements is a good idea, except the current. I think measuring such low current requires expensive equipment. However, we know that each LED of the kind needs between 5-15 mA, so an aproximation can be done.
Hello
I have an idea; ; and if connect the water to the ground with a small copper wire;
Update: I do not know how the device can behave: -can be amplification, attenuation of the signal; the heater can be used as a temporary earthing šŸ˜€
Fighter posted this 27 March 2022
UndisclosedMember, the LEDs luminosity is not their maximum luminosity, I'd say it's like around 50%. About current, my DVM1100 seems capable of measuring mA and even uA, why wouldn't it work ?
I expect to have DC current there at the output of the primary power provider (the one partially submerged in water).
UndisclosedMember, the only grounding source I have is the one from the power grid.
I can give it a try, to connect the water to the power grid grounding wire.
Fighter posted this 04 April 2022
UndisclosedMember, I placed a wire connected to my power grid's grounding connection.
I didn't noticed any change in LEDs luminosity but that's not very relevant, I'll let it work for a while in this configuration to see if there is any change.
I'm curious if the increased luminosity before sunrise is still present.
I should repeat this experiment while taking the measurements to see if there are any variations in current, voltage, frequency and waveform.
Will do that when possible, I still didn't tried to get access to the wires encapsulated in glue.
