Waveform Emergent Mass Theory.
  • 4K Views
  • Last Post 31 October 2025
Apoc posted this 12 January 2025
I didn't know where to put this but I wanted to put it somewhere anyway because I think its important.
Basically I used ChatGPT to talk about how quantum entanglement works, and started thinking about resonance. I was thinking what if somehow entanglement works by the attributes of the particles resonating together.
Thing is then I started thinking about this and wondered, could it be possible that gravity and at the same time mass are just waveforms that warp spacetime to create what we call gravity and mass?
The thought experiment I played in my mind was comparing 3d space to that of a 2dimensional surface of a pond with raindrops hitting it, the larger the rain drop the bigger the wave pattern in the pond when it hits its surface, the smaller raindrop the smaller the wave pattern.
Ok so I had a visual to kind of explain it, next I delved into the math of it (with chatGPT's help because I'm terrible at math). I used chatGPT to check this theory (chatGPT math could be wrong) but anyway I've been trying to check its math and failing miserably because of the kinds of numbers I'm dealing with (talking decimal places in the trillionths).
Long story short, I had chatGPT run the numbers using the frequencies of subatomic particles and calculated them for Hydrogen, Helium, Lithium, Carbon, Iron, and Uranium. Using my method of calculating the frequencies when compared with the known atomic masses on the periodic table every element I tried ended up having a less than 1% error from the actual atomic masses we know versus my emergent mass via waveform concept.
I even went as far as to scale up iron to compare it to 1gram of iron versus calculating the emergent mass of 1 supposed gram of iron and it still held a less than 1% error. I also did it for hydrogen and it was almost exactly the same. So not only does it work at atomic scales like the atomic masses but it can be scaled up to macroscopic scales such as Grams and Kilograms and maybe even further.
My main problem right now is I'm so bad at math entering these ridiculous numbers with ridiculous exponents into a calculator so makes it very hard for me to fact check ChatGPT's calculations. But the fact that basically any elemental atom I feed it, its always able to get a result that's almost exactly the same as that elements atomic mass.
If this can all be checked it has very profound implications to the world of physics and could even unite the standard model with quantum mechanics, and who knows what else this could help discover if it ends up being true.
AlteredUnity posted this 31 October 2025
In May 1921, Walter Russell entered what he described as a 39-day “cosmic illumination” — a state of expanded consciousness in which he claimed to perceive the inner workings of the universe directly. He later compiled his insights into The Universal One (1926). He sent this to hundreds of leading scientists and thinkers; most dismissed it as metaphysical speculation, except Nikola Tesla, who is said to have told him:
“You have caught the light of cosmic understanding… but the world is not ready for it for another thousand years.”
Russell claimed that matter is not a substance, but a form of motion — specifically, light that has been compressed, slowed, and patterned by rhythmic thought or “Mind.”
Compression (contraction) = gravitation, forming matter.
Expansion (radiation) = the return to the undifferentiated ether or “universal mind.” This compression/expansion cycle is the basis for all creation — not static particles, but oscillatory energy transformations.
He saw this as octave-wave motion, analogous to musical scales or light spectra, where all physical phenomena are variations of rhythmic pressure in a single continuum.
Russell rejected the dualistic idea that forces are separate (like matter vs. energy, or positive vs. negative). Instead, he proposed a “One Substance” — the universal equilibrium — manifesting as alternating polarities:
Attraction ↔ Repulsion
Heat ↔ Cold
Condensation ↔ Rarefaction He emphasized that these are two phases of one balanced process, not two independent forces. The universe, in his view, is a rhythmic heartbeat of the cosmic mind, not a mechanical system of particles in empty space.
In Russell’s cosmology:
Electricity is not electrons moving through a void, but spiral vortices in a dense, balanced medium (a “plenum”).
The vacuum is not empty but full of latent energy, a field of opposing rotations (similar to what quantum field theory would later describe as vacuum fluctuations).
The wave is the fundamental construct of matter — its nodes and antinodes define atomic structure.
He described atoms as wave fields, with rhythmic compressions and expansions forming standing waves — decades before quantum field theory and wavefunction interpretations became mainstream.
Russell extended these principles into biology and metaphysics:
Life and death are simply the compression and release of light patterns.
Time is helical, not linear — meaning evolution and recurrence coexist, like spirals around a central axis. --(This part was strange to read, as a few months ago in a dream I was sliding down a helical surface, as I continued to slide I realized I could probably jump to the former part of the surface I was sliding down, and end up in the past part(or phase) of the helical slide I was on.....)
This view anticipates the cyclic cosmologies and fractal time models in later systems theory and even some quantum cosmology interpretations.
Relation to Modern Concepts
While his system is philosophical rather than mathematical, it parallels several modern ideas:
Quantum field theory (QFT): Everything is an excitation in a continuous field — similar to his “plenum” of potential.
Wave mechanics: Russell’s octave-wave model resembles standing wave structures of particles.
Nonlocality and entanglement: His “universal mind field” implies all things are interconnected through phase relationships.
Morphic resonance and consciousness research: He saw thought as an organizing principle of matter — similar to Sheldrake’s later ideas.
Vacuum energy and zero-point field: His “universal equilibrium” resembles the modern view of vacuum as a sea of energy, not emptiness.
