  • 19K Views
  • Last Post 18 December 2022
Hello all,
YoElMiCrO posted this 10 November 2022
@ Itsu.
You can't find the resonance frequency due to
that the Q of the inductors is 1, that is because the load
that you have coupled in parallel destroys it.
I propose you to perform this experiment and tell me
if you managed to find it.
You will see that the tension that appears in the union of the
inducers does not obey under any concept to what
there should be if you do the math.
Thanks you.
Fighter posted this 10 November 2022
Replying To: Itsu
Thanks ☺️
No, unfortunately after more than a year of experiments my MEG replication was not successful.
But that unsuccessful replication was actually the base platform where my ZPM device development started from.
Shelfordella posted this 11 November 2022
When the switch closes, the source is powering the coil and the load, maybe it will be working if a second switch is added between the coil and the load with an inverted  driving signal, so the load is powered only by the coil.
Itsu posted this 11 November 2022
Replying To: YoElMiCrO
YoElMiCrO,
Yes, the load of my 3x 12V / 5W bulbs is about 9 Ohm or so, so rather heavy.
But that is also the case with Fighter his setup i guess, so he also should see no resonance due to the (over)load of his bulbs parallel to the Coils.
When following your experiment (no load, a STTH12R06 diode between coils and drain MOSFET, 15V input voltage) i get the following screenshot:
yellow: voltage signal between L2 and diode,
purple: voltage signal gate MOSFET,
Green: current input PS.
So we do see a resonance around 150kHz 👍
Not sure what you mean by:
Thanks,   Regards Itsu
Vidura posted this 11 November 2022
Replying To: Itsu
It refers to an effect which appears with parametric resonance, on the tap between the two coils a very high potential appears, it is likely that a neon globe will lite when approaching this area. It depends on the relationship of the inductors and other parameters. It is very similar to the hot end of a Tesla resonator.
Replying To: Vidura
Vidura,
OK,  thanks,   i will try to check this with a neon bulb, a loose hanging probe or even my HV probe.
Replying To: Itsu
Thanks ☺️
Fighter,  thanks,   i bought the AMCC-200 core for doing a MEG replication, and might do it lateron, but i have heard about to much failed replications already.
Quoting:Shelfordella
Shelfordella,
thanks for the idea, might be something to look at to separate the BEMF pulse from the input.
Fighter posted this 11 November 2022
Quoting:Itsu
No problem !
Actually I may reconsider, I came to the conclusion that I didn't had all the required information and understanding at that time.
I don't want to go off-topic here or to derail your ZPM experiment but seems the way J.L. Naudin and all of us understood how MEG works is incorrect, actually as Tom Bearden says about MEG at 11:51 in the video below:
The biggest action in the MEG is an electric field transformer not an magnetic field transformer...
Basically, unlike any other transformers in the world, MEG is employing the Aharonov-Bohm effect to concentrate and gather the zero-point energy in form of uncurled electric field formed around the core.
I'd wish I'd had this information when I worked on replicating MEG !
That's why I prepared and started an experiment which seems to confirm what Tom Bearden said:
https://www.beyondunity.org/thread/aharonov-bohm-effect-as-zero-point-energy-concentrator/
When you have some time read the thread and especially watch the video, I think you will find it interesting as it could change the way we understand how MEG works.
Personally I intend to continue the experiment when possible as this principle have the potential to be useful in any of our devices not only in MEG and could be a huge advance in our research.
Quoting:Itsu
Shelfordella,
Hi Itsu,
you're welcome. That's not exactly what I meant, but this is a good idea  to try too. What I meant was separating the input pulse from the load, so that a pulse only powers the bucking coils. Also, the resonant frequency is dependent on the time constant L/R, more load in parallel equals less resistance equals higher time constant equals lower pulse repetition rate required to complete a full cycle. There isn't really a resonant frequency, but instead an optimal repetition rate.
