  • 17K Views
Itsu posted this 23 November 2022
YoElMiCrO
thanks for your insights, it seems you have it nicely figured out and presented clearly πŸ‘
If we apply your formulas to my situation we have this screenshot there:
Yellow input voltage 24V
green input current
red math function yellow * green = input power
we see little current going back into the DC source and we have following data:
Rcu is 0.9 + 1.5 = 2.4 Ohm,
Rds (on) = 0.055 Ohm (IRFP260N)
Edc = 24V
Freq. 213kHz / T = 4.7us
Duty cycle = 25%   Ton = 1.175us
thus according to your formulas we have:
Ip = Edc/(Rcu + Rds (on))
Ip = 24/2.455 = 9.77A
and:
Pp = Edc*Ip
Pp = 24*9.77 = 235W
Pavg = Pp*(Ton/T)
Pavg = 235*(1.175/4.7) = 58.7W
But as can be seen in the screenshot, the Ip is much less (3A), and thus Pavg (11.38W)
This Pavg is so low that my MOSFET is barely heating up without heatsink.
So i wonder where the difference comes from between your calculations, my results and Fighters results.
Vidura posted this 23 November 2022
Here I will put a video from a test that I made earlier:
Despite that I didn't get resonance, the observed DC component could cause the saturation of the core and explain the high curre during t-on
YoElMiCrO posted this 23 November 2022
@ Itsu.
No, it's not!
That current you calculated is the maximum possible
to extract from the source for your replica.
In your case the current is triangular, it is logical due to
to the total inductance connected to the Sw.
The inductance would be...
Lt=(N2-N1)(N2-N1)Al.
Its di/dt=Edc/Lt.
Since Rds(on) is much smaller than Rcu, it is negligible.
That's why your mosfet doesn't heat up, in fact it doesn't work for you.
because the core is not saturated...
For your case, the calculation would be as follows...
Ipk=EdcTon/Lt=3A.
Pdc=(0.5IpkEdcTon)/T+Losses due to joule+ effect lost by Sw+ those of the core, etc.
Pdc=(0.5*3*24*1.175)/4.7=9Watts.
In touches the losses would be...
11.38-9=2.38Watts.
Your efficiency would be...
(9/11.38)100=79.36%~80%
A normal case for electronics as we know.
I hope it helps you.
Quoting:Vidura
Hi Vidura,
thanks for your video / tests.
You mention you have no resonance, but you also mention that the neon bulb lights up due to resonance, so i wonder how that can be.
Does a neon bulb not light up at anything above 45 and 65VAC regardless there is resonance or not?
See my earlier post where i measured the centerpoint between the 2 coils to have something like 90V:
https://www.beyondunity.org/thread/fighter-s-zpm-zero-point-module-replication-by-itsu/?p=6&order=all#comment-a0987e26-9f7a-4428-8de7-af4b0020f571
Anyway, another point of interest is your statement about the used FG as it is somewhat "weak" compared to other FG's, so i might try another stronger FG to drive the MOSFET.
Thanks Itsu
Quoting:YoElMiCrO
@ Itsu.
No, it's not!
Its di/dt=Edc/Lt.
Ipk=EdcTon/Lt=3A.
11.38-9=2.38Watts.
YoElMiCrO
you are a wizzard with formulas πŸ‘
So you think my main problem is that my core is not saturated.
Using your formula; Ipk=EdcTon/Lt=3A i can calculate my inductance Lt (at 213kHz) by:
Lt = EdcTon/Ipk
Lt = 24*1.175us / 3 = 9.4uH
Looking at my inductance sweep using my nanoVNA which i showed on my OUR.com thread here:  https://www.overunityresearch.com/index.php?topic=4374.msg101682#msg101682
It seems very close looking at the 213kHz line (marked red):
So i guess i have to find myself a real Hitachi AMCC 200 core and put up 2 full coils like Fighter 300 turns and 150 turns (i now have 200 : 100 turns), and hopefully it will saturate.
Thanks,  Itsu
Fighter posted this 23 November 2022
Quoting:Itsu
YoElMiCrO
Yes he is... ☺️ Yoel's posts are always insightful, I learned that while presenting my experiments with ZPM but also while making other experiments. He always make people think and see things from a different and fresh prespective.
Quoting:YoElMiCrO
... Or before getting a Hitachi core try with 150/300 turns on the actual core, why not ?
If that would saturate the core and it works correctly as ZPM then you can use your actual core not only for ZPM replication but also for future MEG replication.
If not then the second option is to get a Hitachi core I guess.
Quoting:Itsu
Quoting:Vidura
Hi Vidura,
Thanks Itsu
Some parts of the video I didn't remember, yes there was a resonance when the load was not attached, at low frequency, but with the load I failed to get the effect like fighter at several hundred kHz. Regarding the SG , I discovered when working with the switching module, that a square wave with the same amplitude as a microcontroller for comparison delivered only around half of the current with the same load (led of the optocoupler and serial resistance)attached.
... Or before getting a Hitachi core try with 150/200 turns on the actual core, why not ?
Yes, i could do that, but need to order more 0.8mm magnet wire as i did ran out of it during the winding of the first ZPM therefor only 100/200 turns.
Replying To: Vidura
Thanks Vidura,
i know these little Chinese SG's i use now are weak in signal, but the switching board (with MOSFET driver) boosted the signal, but now i am running this SG straight to the MOSFET, so it might fail to switch properly or so.
I will see.
Fighter posted this 24 November 2022
Correction, I just noticed this mistype, I meant to say 150/300 turns, I edited my previous post.
  • YoElMiCrO
