RIGOL MSO5000 Live Monitor (Hacked FW Compatible)
  • 6.5K Views
  • Last Post 01 May 2026
baerndorfer posted this 12 July 2025
Hi all,
because i was not very satisfied with Web-View from Rigol for my MSO5000 i build my own one.
This tool provides a live view and SCPI-based data extraction from a **Rigol MSO5000** oscilloscope with **hacked firmware** via VNC and VISA (SCPI) interfaces.
The script displays:
- Live screenshots from the oscilloscope (via VNC)
- Channel information including coupling, bandwidth, scale, offset, and probe settings
- Trigger and timebase settings
- Raw waveform statistics (Vpp, Vavg, Vrms) for up to 4 channels
- A scrollable debug log for diagnostics
## Requirements
This script is written in Python 3 and depends on the following libraries:
| Library    | Purpose                            |
| `tkinter`  | GUI interface                      |
| `Pillow`   | Image processing for screenshots   |
| `numpy`    | Numerical processing of waveforms  |
| `pyvisa`   | SCPI communication over TCP/IP     |
| `vncdo`    | VNC client to capture screen image |
### Install dependencies
Make sure you have Python 3 installed, then:
```bash
sudo apt install python3-tk python3-pip
pip3 install pillow numpy pyvisa
sudo apt install vncdo
> Note: On Debian/Ubuntu systems, `vncdo` is often available as a package. If not, install it via `pip install vncdo`.
##How to Use
```bash
python3 rigol_vnc_liveview4.py
You will be prompted in the terminal to enter the IP address of your RIGOL MSO5000.
Make sure:
- The oscilloscope is on the same network.
- VNC is enabled on the oscilloscope.
- The oscilloscope responds to SCPI commands over TCP/IP.
##Hacked Firmware Notice
This script is optimized to **avoid crashing or hanging** when used with unofficial / hacked firmware:
- Timeouts are reduced
- Some known problematic SCPI queries are skipped or blacklisted after failure
##Screenshot Path
By default, screenshots are saved temporarily at:
/tmp/oszi_screenshot.png
##Customization
You can adjust these in the script:
- `INTERVALL_BILD`: How often to update the screenshot (seconds)
- `INTERVALL_SCPI`: How often to fetch SCPI data (seconds)
- `WAV_POINTS`: Number of waveform points to request per channel
##License
This project is for **personal use only**. Use at your own risk. Not affiliated with Rigol Technologies.
baerndorfer posted this 23 August 2025
the problem with current is, that in special scenarios i am not able to do a correct measurement. no matter what devices i use the calculated values are not 'logic' for me. power calculation become extremely difficult and therefore i started measuring heat and amount of light which comes from the load. but this is not always practicable and thats why i search for new approaches. while programming this analyzer it becomes obvious that i have to find a way to look into this current which looks more like white noise. to analyze white noise data we have some methods which i can use now to look for things, that stand out of this data. things, that should not be there. very interesting patterns are now visible on my screens. it's funny to watch and give me a better understanding what is realy going on here.
when you take a piece of wire (or coil) and put it on some channel on scope you will see that patterns emerge over time.
very interesting to watch.
this new tool is available on 'testing-branch' - Noise Inspector
Fighter posted this 24 August 2025
Vey interesting, so the "white noise" actually have embedded in itself obvious patterns.
It's what we also can see in cymatics:
Nothing is really random in the Universe, everything have its own self-resonant frequency.
As my signature says:
baerndorfer posted this 27 August 2025
at the moment i do heavy testing with the VEC circuit. i changed the source from dc-power supply to a diode-plug. in combination with VEC the energy exchange between source dipole and VEC is 'white noise'. power analysis on grid shows -12W of negative active power when VEC is in operation. the interesting thing is the current which happen between diode-plug and VEC. i did analysis of this current and there are 2 frequencies that script detects. these 2 frequencies give rise to a third frequency which is dominant and in the MHz region.
so for my measurement equipment which by the way is not the cheapest one i am not able to measure the exchange between these 2 devices. But i can measure exactly, what i feed in from the grid. and this is power with a mostly reactive component which in my case produce negative active power.
so it's getting more and more interesting.
current is on CH3
i like the analogy which Fighter brought up with the soundwaves
Jagau posted this 27 August 2025
Hello Bearndorfer
I'm integrating Linux and Python into another PC. I might be able to follow along.
AlteredUnity posted this 01 May 2026
Hey baerndorfer, I hope you don't mind I added a magnetics tab to your program to extract extra data. In the photo's I show only using one coil to extract u, L, B, etc.. This is using a 3c90 core, and as you can see like the datasheet shows the amplitude permiability can reach to 5000. This is a quick test to show what I have so far, and will further explain the improvements.
You are also able to connect current probes to other coils on transformer to extract parameters like Magnitizing current etc.
I beleive your program was locked at the default for sine waves at 50/60 hz. This disabled that.
Also for those who aren't aware, when only using 2 channels you should use Ch1or Ch2 with CH3 or Ch4 to get the best resolution. Ch1-2; and Ch3-4 share the same ADC converter, this gives you 2GSa/s, as opposed to 4GSa/s when using the same ADC. You can use Ch1 and Ch2 at 2GSa/s, then Ch3 at 4GSa/s, but if using all 4 channels they only get 2GSa/s.
baerndorfer posted this 01 May 2026
i never thought that someone will adapt this to his own needs. i was wrong 😎
very impressive!
Still a work in progress, started mainly to be able to see the reflected load current on the primary, as well as the reluctance. It should be everything the Tektronix scope gives you and more for live measurements.
Your setup provided a great inspiration and knowledgeable insight into how to get the needed information, thank you!
In the parameters menu, depending on what setup you are measuring(sinewaves vs pulse), detrend should be unchecked.
Code is fixed, I reuploaded new version in previous comment
