  • Last Post 30 August 2025
UndisclosedMember posted this 16 June 2020
I understand, Fighter. I was confirming what you said about the Hitachi core(s). Your post had me look into that type material, and I was edified by what I found. It brings much to the imagination. Keep those great thoughts/ideas coming. I am understanding more with every post.
Thanks!
-A-
Fighter posted this 21 June 2020
I have some updates.
As you probably noticed I started working on a secondary project for learning purposes:
Fighter's replication of Andrey Melnichenko's GLED
Also I was so intrigued by the recent finding about how Bearden says he used the Aharonov-Bohm effect for MEG that I decided it's worth investing in a experiment in that direction, if the experiment is successfully it would mean a huge step forward for our devices including ZPM:
Aharonov-Bohm effect as zero-point energy concentrator
The ZPM enhancement project remains my main project and I'm gonna experiment with the configuration posted here by YoElMiCrO.
Also hopefully the Aharonov-Bohm effect experiment could provide a big enhancement: a input-free mechanism for the same effect manifesting not only in ZPM but also in our other devices.
Atti posted this 09 July 2020
I haven’t seen this document yet, but the oscilloscope figure is similar to the value presented by Fighter. See pages 104 and 122.  https://ferd041.files.wordpress.com/2016/07/fe_basics.pdf
Fighter posted this 09 July 2020
I didn't knew about this, thank you Atti !
Yes, the waveforms (especially the one from page 122) are very familiar:
Also the device presented there has two opposing coils with 1:2 size ratio.
The difference is that the device has coils one over the other (overlapped) and it has a air core.
Maybe that's the reason why the ZPM waveform (actually Gunderson's waveform because he was the first showing that pattern) has a higher peak before the spring-like section. But the spring-like section is present in both waveforms.
UndisclosedMember posted this 12 July 2020
Hey Fighter, any initial thoughts on the use of Finemet for these experiments? Are you seeing anything to indicate it is worth the price?
Hi UndisclosedMember,
I answered in the Aharonov-Bohm Effect thread here.
Fighter posted this 23 July 2020
I was watching a video from Tom Bearden's "Energy from the Vacuum" DVDs Collection where Bedini explains how Tesla's impulse technology is gathering zero-point energy. There are similarities in the behavior with ZPM and therefore with Chris' bucking coils technologies.
This clarify more ZPM's functionality, basically ZPM have two virtual Bloch walls (on top and on bottom) which are variable in with and which allow the zero-point energy to enter into the system then compress and gather it. This also explains the negative voltage spikes, basically that's the energy gain and that's why, while powering up the light bulbs on the output, ZPM is sending energy back to the DC source, it's seeing it as a load and it's trying to power it up. That's the energy heating up the MOSFETs in my MOSFET driver and it's confusing the readings on my DC source as it's unusual for a DC source to receive energy back from a load.
Basically the negative voltage in the system is our free energy gathered from the zero-point field.
I wanted to share with you guys what I'm learning so I created a video about it:
Atti posted this 25 September 2020
Analogy of effect A-B. It is well illustrated in this video.
On a suspension connected by an abbreviation with a chopstick. This would replace the pace of control. Then a different resonance, i.e. a different rate of load. The difference between the two different resonances is another excitation stage which affects both coils and loads.
Binaural beat.
Another feature used. If two sounds with only minimal differences in frequency can be heard in isolation in our two ears, the interference between the two sounds is automatically created in our head (the auditory subsystem of the brain) and the effect of sound vibrating at the two frequencies becomes practically perceptible.
You can search for a lot of videos about this. Or you can hear it here and even see the figure.
https://hu.qwe.wiki/wiki/Beat_(acoustics)
Jagau posted this 17 October 2020
I was carefully reading the fighter therad and a quote from Yo got me hooked. He Said:
During Ton's time the two beginnings are (+/-) and for Toff (-/+), as the current
it is maximum for the beginning of Toff and the tension increases by the induction of E
the load will see more energy during that half cycle.
 In our experiment Fighter, I think that's a good description of what's going on.
UndisclosedMember posted this 18 October 2020
Hey Jagau and all Readers,
Fighter has a very important machine here! Very important! He is right in its operation and it is AU as he tested and has shown!
Very simply: This does Work as has been stated!
Good Science comes from good investigation and WE are the only ones doing Good Science! Everyone else is pushing Dogma and Propaganda!
We lead the world in Energy Machines simply because of our Good Science and strict Protocol!
Best wishes
