  • Last Post 30 August 2025
Jagau posted this 25 May 2023
Hi Fighter,
Nice video demonstration, we can see that the ZPM gives off a lot of electromagnetic radiation. the LED is continuous at full glow.
When you think about it, this energy that is free can be harvested in different ways, as D.Smith said, the ZPM is the transmitter and the microgen is a receiver.The question is how many receiver can we put without affecting the source?
As much as you want! with real test done.
Fighter posted this 25 May 2023
I agree. The Micro-Generator is "feeling" the extra-energy harvested by ZPM and it's taking advantage of it harvesting in the same time with ZPM.
I also think we can put 10-20 or how many Micro-Generators in the area and that will not affect ZPM's input at all. šŸ™‚
editor posted this 12 June 2023
@Vidura
Hey Friends, Recently I made some tests related to noise , and found that there is some kind of it which is virtually impossible to filter or screen out.
So filtering the noise sent back by ZPM is impossible...
Also it is possible that a lot of power is dissipated in the low frequency rectifier.
This seems to be the case, the bridge rectifier and/or the transfomer become hot in about 10 minutes so those extra ~30W consumption shown by energy meters most probably are dissipated in that heat.
Regarding the change of the wave form of the ZPM when using the simple transformer, could it be a voltage drop the cause? There might be a threshold voltage for the ZPM to perform properly.As the lab PS is voltage stabilized, it is supposed to maintain the selected voltage, no so a standard transformer, there can be major variation depending on the load conditions.
This could be the case of voltage drop. I could make a test with the usual DC source by setting the voltage much below 25V and check how the waveform looks like.
I agree that a battery would give valuable comparison.
I will try this way, I will look for some local supliers for rechargable battery/batteries.
If it is actually some circuitry inside the PS that is interactive , it should be possible to find which components. Some time ago I had an issue with my PS , the current limiting was damaged, so I opened it to check, it is of the analogue type, a multi tapped steel core transformer, and linear voltage regulation, not switch mode type. I was a bit surprised about the few components on the output line, a single electrolytic capacitor , a precision current shunt, and a few more components. The only digital components are the voltage and current meters. I guess the Switch mode type PS has more filter components , to keep the switching noise low. But if Fighters PS is the analogue type, there are only a few possibilities of interacting components.
My DC source is switch-type, I remember I chosen it specifically to be this way, that's why is has about 16kg weight. The model is QJ6005E and the manufacturer's page is here:
http://www.nbjiuyuan.cn/Single-output/products_21_en.html
Unfortunately there are no schematics anywhere on internet but I found a image from inside:
I see that big current-sensing shunt and also I see there are a lot of electronics, some of them could possibly actively working with ZPM but I have no idea which one.
On the manufacturer's site I see this option but it's for measurements when voltage drop occurs, I don't think it will help with high frequency noise:
By the way, I got a notice from costumes about a packet, this could be the metglass core, hopefully, now nearly four months ago was shipped from Europe. So maybe soon I can join the testing of the ZPM.
I would be glad if you could join the ZPM research, having another ZPM in experiments with different power source and measuring instruments will be very helpful in clarifying some aspects and ZPM's behavior !
@Atti
This is just an opinion, not to be accepted but to consider.
In my opinion, the load on the transformer of a single DC source is probably too close to the maximum load. (36 VA)
Therefore, the peak current draws too much down the buffer capacitor voltage. Whirring tension.
Therefore, the input waveform on the secondary side of the individual transformer.
If you could replace it with a larger transformer (maybe 200VA)
waviness would decrease.
Another solution could be to use L-C filters before the ZPM input.
I agree, the voltage drop could be the reason for ZPM's behavior change, I'm taking this into consideration. I could try a test with the usual DC source but setting the voltage much lower than 25V and see how the waveform looks like. About filtering out the high-frequency noise sent back by ZPM, seems it's not a possible solution according to Vidura, seems this is a particular situation where filters don't work. I remember I tried with a choke coil on input and ZPM don't like that, I had extensive damage: DC source entered in auto-protection mode, the light bulbs on output burned and also the MOSFET was destroyed.
If you are using a factory lab power supply, then its wiring diagram would be good to know.
Unfortunately I could not find any schematics on internet for my DC source. You may find more details in my previous replies to Vidura.
Hi all, finaly got the shematic.
PDF in attachment.
Fighter posted this 12 June 2023
Thank you Editor,
Where did you find it ? I searched a lot at that time and found absolutely nothing !
Fighter posted this 16 June 2023
Update:
Editor told me he asked the manufacturer.
Seems he received an answer to the request.
Fighter posted this 20 June 2023
Note to myself:
When I experimented with ZPM having batteries on input here, would a ground connection could made any difference ?..
See Atti's replication here, it's the only ZPM replication working without a grounding connection but Atti says:
there are cases when the current drawn from the power supply is close to zero. There are times when grounding is necessary.
Maybe with a ground connection on the minus of the batteries or on the connection between the coils ?
Also with some variable capacitor/resistor on the grounding wire just like Don Smith used in his devices ?
Don Smith called it "the source of electrons".
Also the fact that ZPM is sending energy back to the DC source should be taken into consideration, it will do the same with the batteries. Probably ZPM will try to "recharge" them, process which could damage them.
That experiment needs to be redone with these variations.
YoElMiCrO posted this 20 June 2023
@ Fighter.
I haven't had time these days to continue
with the analysis of your ZPM.
I am studying Floyd Sweet's SQM in depth.
The ideal is to put a power meter at the entrance of your
power supply and compare consumptions
with or without your ZPM.
The reality is that your ZPM creates a virtual cloud [E]
around him.
But I think I understand that it is that same cloud that
feed your load while only spending what is necessary to
Create.
Hi Yoel,
I tried that long time ago, unfortunately it didn't worked.
Please see my post here.
About the wattmeter, I tried that long time ago and it was inconclusive, it shown much more than the 60V/5A DC source can physically provide and the readings were jumping up and down. It was clear the power meter readings were messed up by ZPM. These things (power meters, standard hand-held non-contact measurement tools, standard multimeters) are made for 50/60 Hz to max. a few tens of KHz, not for hundreds of KHz where the ZPM is functioning.
Remember Editor's freezer being affected by ZPM ? If not check it here. I understood later why the power meter was affected even when placed on DC source's power cord.
@ Fighter.
I'm talking about putting a power meter at the input
of the source, in the AC part, not in the source output!
Measure how much the source consumes without load in its DC output and then measure
with ZPM connected as a load to the DC output of the source.
Quoting:YoElMiCrO
That's exactly what I did. Power meter on the cord powering the DC source.
Power grid socket -> Power meter -> DC source power cord.
The power meter's readings were still messed up by ZPM, they were jumping up and down and it did shown consumption bigger than what the DC source can physically provide. My DC source can provide maximum 60V x 5 A, the readings shown by the power meter were much higher than 300W and were jumping up and down.
I found later a explanation for that in what Editor described in his post here.
  • YoElMiCrO
