BTG research
  • 9.9K Views
  • Last Post 04 May 2024
Vidura posted this 10 December 2022
Replying To: Itsu
If you already have built the circuit, it is OK, it only needs some patience for the correct adjustment of the inductance of the CT. and as the mosfet works in the linear region near the transitions, a good heatsink is recomended. For the improoved version I might open a thread in the hardware-section, explaining a bit how it works and how the designimproovements have been developed. This will be of more benefit for others, and avoid that the circuit will be just be copied without an insight how it works.
Aliengrey posted this 12 December 2022
Hi Vidura
Thanks for your reply regarding the grenade winding I notice the the winding is actuly 3 windings (as per devision by 3)
 also notice in the one video the windings apear to contradict this in aperance leving the viewer (my self) a bit confused
in that the bifilar winding is the same length as the single  winding.
Is it possible for you to show how grenade is actuly wound as i am very interested how to replicate this item as many others will also be Thinking about it, it might be a simple mater of just adding the wave length as a fraction on each winding section if thyats possible .
many thanks & Kind regards Sil
Vidura posted this 12 December 2022
Hi Sil,
In the tests shown on the videos I tried to simplify and investigate the PRINCIPALS, as only by knowing these, a reliable replication by anyone skilled in the art will be possible. These tests where intended to find the interaction of the scalar waves with the main resonator, and have demonstrated the influence of feeding the impulses on different sections, and also the correct location for the ground connection. Still I don’t know if the other principle involved, which is the atomic EXCITATION of the conductor and transfer of the former to achieve the required phase shift can be done with this simplified coil. Next experiments will show this.
Regarding the grenade coil,   it has be confirmed by different  sources, that the following schematic is correct:
 It is important to know, that the Grenade used as main resonator, has to be in LCR resonance, in contrast to the Kacher-resonator. This means that the predominant parameter is the INDUCTANCE, not the length of the wire.
This means that the grenade has 3 sections, as you stated correctly. But these three sections has to be seen magnetically, not physically. I will mark it in the following schematic:
It is likely, that this is not the only possible layout of the main resonator, hopefully the next set of experiments will shed more light on this. By the way, just a moment ago a file which contained all the images from the BTG research has suddenly disappeared from the computer, it seems that somebody hacked in, if it'snot a technical issue.
Fighter posted this 12 December 2022
Quoting:Vidura
Do you mean your computer was hacked ? You should investigate what happened. And keep backups of your research files on separate removable disk or USB sticks.
Run some free antivirus and antimalware on your computer, they should detect suspect things on your computer.
Try with Malwarebytes.
Vidura posted this 13 December 2022
Thanks Fighter, I will follow your advice.
Jagau posted this 13 December 2022
Sorry to hear that Vidura, I'm using an old computer that doesn't have WIFI or internet connection, as a backup.
I'm not sure that a USB key is safe (malware) so that's the way I use for backup. I am not at all an expert as a fighter in this field.
Atti posted this 13 December 2022
Vidura.
Unfortunately, I know of such a case. In the past, I would not have thought of this, I accepted it with doubt.
About a year after I first joined the previous forum, I also had the same problem with the virus. So if you can, find the "visitor" and identify it. If you can, consult an IT specialist.
Aliengrey posted this 13 December 2022
Thanks for the coil info it looks a bit like the Stalker device except he had it tuned to a different frequency I notice yours is tuned to 432 which is an interesting difference.
Hi to all
Yeah; malware bytes are good I used them for a good wile, there is also 'AVG antivirus' that will find and neutralise that nasty virus that targets JPeg picture files, AVG runs all the time looking for and warning of bad sites and scans any plug in
SD card Stick or Hard drive. There is also 'CCleaner' but some of the older versions Have more facilities for wiping unused parts of a disk, a smaller disk size is easier To maintain.
The other thing is if some guys have no protection they wont know the damage they do.
Sil
Munny posted this 14 December 2022
Question I had with this device where I never got what I would qualify as a satisfactory answer was the 1-to-100 frequency modulation.  Why does the high voltage have to be exactly 100 times higher frequency than the high current from the push-pull?
I understand hetrodyning but I (so far) cannot see any relationship and the 100 factor seems arbitrary to me.
Does anyone really know?  Did Akula explain this someplace and I didn't pick up on it?
If we flip frequency into bandwidth does this 100 factor now make more sense relative to the wire lengths involved?
Does it have something to do with velocity factor of the insulated wires?
Sure wish somebody could give me a definitive answer because I would think the answer embeds the foundation of how this device really operates, which to me still seems like some kind of magical mixing of high voltage/low current with high current/low voltage to end up with moderate voltage/moderate current that is usable.
Aliengrey posted this 14 December 2022
Quoting:Munny
Hi Munny
if the start freq is 1.8 mhz and the wave length is 4166.6  and it's divided int blocks of  3 where do you get 100 ?
Sil
