BTG research
  • 9.9K Views
  • Last Post 04 May 2024
Fighter posted this 23 December 2022
Just for inpiration.
Does it look familiar ? See the outer coils placed at distance ?
This is not an ordinary device and clearly it's not built like the transformers we know today.
It's built by Nikola Tesla and looks like this is the kind of device which inspired Kapanadze and Akula when they built their devices.
Unfortunately we can't see the coils inside the metal cylinder but they're there, see the wire going inside the cylinder.
bigmotherwhale posted this 24 December 2022
Quoting:Vidura
Replying To: Aliengrey
Yes we need the standing wave in the TC, as E-field generator, it was there in the last tests, but not properly received or converted in the main or output coils.
In my opinion, The standing wave should be in the opposing coils and the TC should have a unipolar pulse that acts a dc bias.
Aliengrey posted this 24 December 2022
Vidora Hi
What I need to ask you is what is the wave length of your TC  to find this you need an Os'Scope and a Gig gen and you need to find where the second  node is at the end of the winding,  make sure there are no other active nodes  the note that frequency.
WHAT IS IT ?
regards Sil
Vidura posted this 24 December 2022
Nice coil😄
Tesla used this kind of resonators (free oscillating coils) to produce dampened waves, as kapa, ruslan ,akula did later.
There is a document of an interview with Tesla and an agent of the patent office, where he explained the purpose of the dampened waves, resuming he states that if the energy is directed prevailing to the ground , it can be totally recovered, but if it is irradiated it is lost. The enclosure could be a container for oil, which prevents streamers.
Quoting:bigmotherwhale
Quoting:Vidura
Of course, there is also a standing wave in the reception coil, as it is in resonance, but with the push-pull it wont have sufficient potential to lite a neon nearby, this only happens when the scalar wave from the HV source is properly received. Have you managed to get a unipolar pulse from a TC?
Quoting:Aliengrey
Vidora Hi
WHAT IS IT ?
regards Sil
When I have time I'll do the measurement. But note that the kacher is selftuning, it will always oscillate as 1/4 wave resonator, but the wavelenght depends on the parameters of capacitance, thus it changes when the antena is connected, or the receiving coil mounted. Also the ground wire has some influence.
Quoting:Vidura
Quoting:Vidura
Yes unipolar pulse is a pulse going one way posative or negative but one and not the other as that would be a bipolar pulse,  my wave length is 1.5Mhz so to get another node at 3Mhz i have to retune my SG to that frequency and all i get is a sine wave and uless its got to be driven by a square wave I get nothing
Have you any idears ??
Sil
Any coil or peace of wire has its own resonant frequency, and will always vibrate in the same, or any harmonic of it. Regardless how it is excited it will vibrate according a sinusoidal law. If you hit a bell you can't expect wind coming out, only sound . The most similar output to a unidirectional pulse would be produced by a nanopulser, and even here we could expect the dampened wave from the coax cable, although in the 100mhz range for a short length of one meter approximately.
A short update. As the latest tests didn't result as expected, I went a step back and tried the transfer without the push-pull stage, and found the problem there. It seems that the earlier assumption of related wirelenght was correct, with the two actual receiving coils I couldn't get not nearly a good result as in the earlier experiments with wavelength relationship. So I will have to get more wire and rewind the coils to confirm that.
