Replication Don Smith's Device No. 9
  • 6.7K Views
  • Last Post 05 June 2026
ScientificVoyager posted this 10 February 2026
For some time now, I have been interested in Don Smith's replica No. 9. There is not much information about this device, but I decided to make a small replica of it.
Any information about this device would be greatly appreciated.
I have conducted some small tests and the results are really interesting because I managed to light a small bulb with two small coils, magnets and a steel disc with holes.
When powering the motor rotating the disc and connecting the load to the coils, the motor driving the steel disc did not feel any resistance while the bulb was lit, with no change in current consumption. That is why I found the effect very interesting and decided to do something more meaningful.
I am in the process of gathering materials and will share my observations with you from time to time.
In general, I have made a wooden structure to put it all together. I commissioned a company that laser cuts such things to make metal discs. The first discs will be made of ordinary steel. I designed the coil spools in FreeCad and they are being printed. Now I am waiting for a delivery of silicon sheet metal to make the coil cores.
Has anyone attempted to investigate this effect?
Jagau posted this 26 February 2026
Hello scientificVoyager, very nice work you are doing.
 Perhaps this can help with your project.
In Rick Friedrich's book, page 102, there's an image that clearly shows the position of the coils and holes.
He claims it uses magnetostrictive material, which is interesting in this image –
 look at how the two coils are connected! in opposite phase.
ScientificVoyager posted this 26 February 2026
Hello Jagau.
I keep staring at this photo, trying to figure out the significance of the individual components.
Coils with opposite phases combined with a rare-earth metal, such as Terfenol-D, could produce the desired effect. I'm wondering why there's no diode bridge at the coil output; could it be that the output is DC?
Magnetostriction is the phenomenon of distortion in ferromagnets (materials exhibiting spontaneous magnetization) under the influence of a magnetic field. The opposite effect to magnetostriction is the Villari effect, which is a change in the magnetization of a material due to a change in its external dimensions.
Symmetrical phenomena are used in transducers, sonars, ultrasonic cleaners, etc.
Schematic diagram of a transducer with a core made of magnetostrictive material.
Materials with incomparably high magnetostriction are called GMM (Giant Magnetostrictive Materials). At 0.2%, they can withstand loads of 500-600 MPa. What distinguishes them from conventional materials is their very fast response time to a magnetic signal. It is understandable that to achieve significant magnetostriction, a material with a high response of its magnetic domains to the effects of a magnetic field must be used.
Therefore, the development of a new group of special materials based on rare earth elements such as terbium (Tb) and dysprosium (Dy) proved to be a breakthrough. The general chemical formula of GMMs, known as Terphenols, is TbxDy1-xFey. The most popular and currently most widely used rare earth alloy with iron is the alloy with the composition: Fe = 67.5%, Tb = 9.6%, Dy = 22.9% (Terphenol-D).
Look at what Don Smith answered when people asked him the question.
Hi Don,
Is it possible that you vary the speed of the motor to find/make the two coils and the two Caps. all in series (series LC circuit) resonant thereby increasing their efficiency/output? It would seem that a full wave bridge diode would be necessary to keep polarity correct into the battery/load if DC wanted.
Ben
You are correct . What you see is the simplest possible drawing . I assume a knowing person would know the difference . REGARDS, Don Smith
You are correct . The variable speed switch is from an automobile dimmer . The drawing is the simplest possible and is therefore incomplete . The basic idea is clearly shown . REGARDS , Don Smith
Don, et al
This has some similarities with the Ecklin SAG generator  (http://www.montalk.net/ecklin/ecklin.html).
You seem to be using the rotating wheel simply as a magnetic field blocker. Correct? What materials are you using as the blocker? Is it possible to use a flux carrier like METGLASS instead of a flux blocker?
Interesting stuff. I want to build an Ecklin SAG sometime, but may try yours instead.
Roland
My “Rotating Separator Coil” one of a dozen related projects I did. It’s my improvement over the Henry Ford Generator Starter Motor . The Aircraft Industry has starter generators in mass production which produce excess energy and with minor change are self sustainable ” 60 Kilowatts and upwards of excess energy” . Thanks for the comment . REGARDS, Don Smith
But you can´t get KWatts out of it, when you just use a simple milliWatts motor to drive the shield ! That just does not work.  Has anyone from this list seen any of Don´s machines work ?
As Don was already at some conferences also at Bruce Perrault´s conference lately there must be some people out here, who have seen his presentation. Please come forward and speak out. Thanks.
Stefan.
P.S: To me it sounds like Dom is only here to sell his expensive CDs with no real value…
The small millwatt motor shown powers only the rotating disk . The output is from the magnetic variation resulting from the shielding . Which is quite large . REGARDS , Don Smith
Thank you for the valuable information.
ScientificVoyager posted this 27 February 2026
Today I played a little with my toy and carried out a test according to this drawing.
This experiment aims to show that the generated current does not affect the motor load if we use two halves of the current sine wave.
I haven't had this much fun in a long time and I'm posting a video of the fun, sorry for the audio quality, it might be annoying.
s
My current waveform on the oscilloscope doesn't look the best at the moment and is closer to a sawtooth waveform.
With a single coil, I have an uneven magnetic field distribution on both sides of the disc, so this isn't necessary at this stage. As I mentioned earlier, the goal is to confirm whether the current produced is causing motor resistance, which I don't think is the case. If there are two coils and an even magnetic field distribution relative to the disc, the waveform will be a pure sine wave.
My replica device looks more like the Russian device from the video on the first page of this thread than Don Smith's, as the DS device relies primarily on the principle of magnetostriction (very expensive and scarce rare earth minerals). So, for now, I'll continue in this direction and see where it leads.
Fernando posted this 27 February 2026
Wow, very nice video and testing, your system is very neat, more speed more current and régénération under load?. Thanks for shearing your progress, in the past I try to replicate, but you offered new way to do It. 😃😃😃
Hello Fernando.
Thank you for the kind words, which give me even more motivation.
A second test with two coils is coming soon. I can't really do thorough tests, I'm waiting for a new disc holder because I'm currently experiencing lateral runout and the whole thing vibrates at higher RPMs. I plan to order larger magnets because the ones I have are clearly too small, smaller in diameter than the core (I already had those).
It's nice to feel like a little kid again
Best regards
andy2 posted this 27 February 2026
It looks great!!! 👍👍
42Vpp just witn only one coil? then with multiple cols it will blow your ceiling :-)
I think it than Smith's "magnetostrictive materia" can be only cover that it works without it too. Or its add only some additional power and it is quite fine go without it - as is seen in your video.
Fingers crossed
P.S. what was you rpm in slow and fast rotations in video?
Quoting:andy2
Thanks. Yes, a single 500-turn coil, 0.5mm diameter wire, inductance without the steel core inside is 5.5mH. The probe and oscilloscope are set to 1:10, which I forgot to show, I'll fix that . The magnets are really tiny, 15mm in diameter and 8mm thick, type N38.
At idle speed, we see a frequency of 246 Hz on the oscilloscope. Dividing it by the 8 holes in the disc gives us 30.75 Hz, and times 60 seconds = 1845 rpm. In the second case, at higher speeds, we get: 470 Hz/8 * 60 = 3525 rpm.
baerndorfer posted this 27 February 2026
i watch your thread with great interest. i know a bit obout don smith but have not tried out, what you actually started. a thing that don smith never mentioned (or maybe i missed it) is, that if we can remove counter-emf force which acts on primary then our generator will deliver for free and can run with very less input. maybe this is what we all like to have.
yesterday i watched a video that i like to share. hope it helps!
have a nice day
