Simplicity and power of ether
  • 9.3K Views
  • Last Post 2 weeks ago
Jagau posted this 08 March 2026
 This Polish man named Pachuka does incredible things. Watch this video carefully.
He excites the ether with a 9VDC battery and then disconnects it; the circuit becomes self-sufficient, with the ether supplying the voltage to the lamp.
Jagau posted this 10 May 2026
Nice work, B.
The hardest part is replicating the second coil with the same parameters.
If you have the time, place a spherical capacitor on top of the left coil; the effect will be amplified during energy transmission between the two coils. As Meyl explained, they act like two plates of a capacitor relative to the ground.
N. Tesla said that for better results the left coil should be a quarter-wave resonance coil and the right one a half-wave coil.
worldcup posted this 13 May 2026
Might come handy !
Jagau posted this 14 May 2026
You probably know, Wordcup, that an LED lamp like the one shown in the video above only needs a few watts, about 5 to 6 watts, for the equivalent of 40 watts at full brightness.
His output transformer connected on 220 V has a 10V, 1.2 A output about 12 watts.
Sorry, I don't see any increase in input versus output in this video.
A very informative video here on Standing Wave, Node and Reflection
Tesla experiment's
You will better understand N.Tesla's expression on true wireless.
baerndorfer posted this 14 May 2026
i have a side question here...
why can we assume, that there have to be a virtual (parasitic?) capacitance on the end of wire (from HV coil). ? and on bottom too ? is it easier then to explain  such behaviour with formulas?
if so i think it would be better to assume a RLC-network maybe.
the videos are very good by the way
Yes B, that's a very good question. will try to answer you!
As you saw in the video, it's at the Rx coil, so that assumes our good old earth which provides this capacitance (which I consider real), is between the top  of TC and allows the current to enter from the bottom, with the voltage hot point or anti node at the top and the current node at the bottom(node point), like in Tesla's diagram of capacitances. When the transmission speed of the Tx coil is close to one, at the Rx coil the Tesla effect occurs. I've tried different arrangements, and it works as Tesla described. Remember TEM must be lower as possible, it is not inductive transmission of energy.
Spigel demonstrated that by placing the load at the bottom of the TC, the current actually comes from our good old earth. Nikola Tesla explains it a bit, but in different patents. The first time I saw this, I asked myself the same question as you. I tried it, and it works exactly as Spigel demonstrated.
In my upcoming video, which I haven't had time to finish, I also demonstrate this by connecting the load to the bottom with connection at the base and without connection at the top just by a capacitive effect.
worldcup posted this 17 May 2026
Extracting energy from space is not a mystery. Here is a simple example of how it works. Of course, you can't see everything, we have Hidden a part. This is know-how. If you want to know more or participate in the development, contact us.
Receiving space energy. Simple presentation. (ether)
https://www.youtube.com/watch?v=S90WLinIJGE
@Jagau, Pachuka's YT circuit works or it's another hoax !
Offtopic: In our IT domain, we have these almost magical words and techniques that revolve around the concept of being 'Hidden.' I find it quite funny that whether it's Free Energy (FE) or software engineering, there always seems to be something 'magical' or 'hidden' involved. Take for example 'Heaven's Gate' (such techniqies are not documented directly in syllabus , rather one needs to do some hackish engineering - a technique detailed here: https://0xk4n3ki.github.io/posts/Heavens-Gate-Technique/
Nevermind...
baerndorfer posted this 17 May 2026
i changed my setup a bit. now i use a G3R45MT17K as switch. compared to IRFP640 it is not 'better'. i managed to build a identiccal seccond coil and for a short test i placed it in the nearfield from sourcce dipole.
the bulp lights up when i connect earthground or another potential (sheet of metal).
next step is to build some top-loads.
have a nicce day
Jagau posted this 18 May 2026
@ B, Sorry I was away for a few days.
Yes, great information you've demonstrated here.
You managed to transform reactive power wirelessly into active power on the small lamp.
@ WorldCup, thanks for the video, I'll watch it.
Jagau posted this 19 May 2026
Hi B
Look at this ''Electrical experimenter.. diagram fig 2 special capacitor and fig 6
Do we did it?
