Simplicity and power of ether
  • 9.3K Views
  • Last Post 2 weeks ago
Jagau posted this 08 March 2026
 This Polish man named Pachuka does incredible things. Watch this video carefully.
He excites the ether with a 9VDC battery and then disconnects it; the circuit becomes self-sufficient, with the ether supplying the voltage to the lamp.
baerndorfer posted this 19 May 2026
in diag2 he shows how  the primary is excited. i think every method is good as long as resonance is achieved. fig6 is the top-capacitance compared to capacitance from other side (our L2 coil). it should be Earth/ground because this whole paper is about transmitting energy through one wire (earth).
maybe i'm wrong but this is how i read it
thx for uploading such papers.
this is what i plan to use as top-load ))
found here
Vasile posted this 20 May 2026
Look at this ''Electrical experimenter..
Thank you for posting this. Really good info. Can you imagine the posibility of existing a totally different method of propagating information, invented more than 100 years ago, with articles writen by the inventor itself and the majority of people not even knowing about it? Mindblowing...
Jagau posted this 20 May 2026
N.T wrote:
How to collect the energy in the receivers coil?
A periodic impulses pass thru the wire, differences of potential will be created along the same as well as at right angles to it in the surrounding medium and either of these may be usefully applied. Thus at a, a circuit comprising an inductance and capacity is resonantly excited in the transverse, and at b, in the longitudinal sense.
At c, energy is collected in a circuit parallel to the conductor but not in contact with it, and again at d, in a circuit which is partly sunk into the conductor and may be, or not, electrically connected to the same.
 It is important to keep these typical dispositions in mind.
The description is so explicit.
quoting Vasile
Can you imagine the posibility of existing a totally different method of propagating information, invented more than 100 years ago.
As I've often said, cell phone (half a watt Transmitter) communications work on this principle. Here's the proof:
N. Tesla has been copied again without receiving any acknowledgment, déjà vu!
Shadow_ posted this 05 June 2026
hello
I'm trying to recreate the layout
I am currently waiting for two transformers and air? coils 0.16mH and 10Watt bulb
Jagau posted this 05 June 2026
A compact Hendershot circuit looks interesting.
Unfortunately, my experiments are on hold due to major renovations at my house; I don't have access to my lab. I hope to be back next week. Happy experimenting, Shadow.
Inception posted this 05 June 2026
That makes two of us. My home renovations are almost finished. Bonne courage!
Watching the video of Hendershot's circuit, we see that the north-south polarization of the magnet closes the air gap and lights the lamp, an interesting concept.
You have a lot of parts already assembled in the circuit, Shadow, it will be interesting to follow.
Jagau posted this 13 June 2026
Okay, I'm slowly heading back to my lab.
I built two coils at 2.34 MHz, with the propagation speed adjusted by the capacitor placed above them. This produces interesting effects, with a point between the two where there's no activity. Is this what NT was talking about regarding the tunnel effect?
The most important thing is to tune both coils to the same frequency using the top capacitor.
I'll show a different effect in a short video later.
Jagau posted this 15 June 2026
New video on the two 2.34 mhz coils
The tunnel effect is clearly visible. Note that it takes an electric field of over 70 volts to power a neon bulb.
At the end, the 40W LED lamp is grounded, I removed the 110v circuit from the LED lamp and connected to one side of the L3 output coil. The power consumption is at most close to 1 watt, regardless of whether a lamp is connected or not.
We have here a high electric field and a very low magnetic field.
