Simplicity and power of ether
  • 9.3K Views
  • Last Post 2 weeks ago
Jagau posted this 08 March 2026
 This Polish man named Pachuka does incredible things. Watch this video carefully.
He excites the ether with a 9VDC battery and then disconnects it; the circuit becomes self-sufficient, with the ether supplying the voltage to the lamp.
Jagau posted this 20 June 2026
Something to think about
From the book by Bahman Zohuri: ''Scalar Wave Driven Energy Applications''
Scalar Wave is a non-linear, non-Hertzian (does not diminish with distance) standing wave capable of supporting significant effects including carrying information and inducing higher levels of cellular energy, which greatly enhances the performance and effectiveness of the body and immune system. Additionally, it helps to clear cellular memory by shifting polarity, similar to erasing the memory of a cassette tape with a magnet. Scalar waves travel faster than the speed of light and do not decay over time or distance.
Doctors and biologists are not able to tell us what life is. They cannot explain in a proper way how cells communicate with each other. Modern science focuses on chemical reactions, however, that is not the whole picture. The most important communication tool in the body has not been detected by mainstream medicine yet because of the huge conspiracy against Scalar Waves. A human’s body works with Scalar waves (an aspect of neutrinos). The body also constantly is generating these universal Scalar Waves.
Scalar waves are produced when two EMWs of the same frequency are exactly 180 degree out of phase (opposite to each other) and the amplitudes subtract and cancel or destroy each other. The result is not exactly an annihilation of magnetic fields but a transformation of energy back into a Scalar Wave. This scalar field has reverted to a vacuum state of potentiality. Scalar waves can be created by wrapping electrical wires around a figure eight in the shape of a Möbius coil. When electric current flows through the wires in opposite directions, the opposing EM fields from the two wires cancel each other and create a Scalar Wave.
Jagau posted this 21 June 2026
Remember my experience with Non linear Resonance, page 5
https://www.beyondunity.org/thread/non-linear-resonance/?p=5
Two pulsed coils at 180 degrees out of phase. The result was very interesting, if we collect what happens at the point of convergence of the 2 coils, the Beyound-unity is clearly present.
baerndorfer posted this 21 June 2026
a few days ago i made a very interesting observation on my receiver coil. when i put a ordinary coil on base from receiver, then i cannot extract energy from that coil. it makes sense somehow, because there is 0 voltage.
BUT !!! as i changed this ordinary coil with a opposing-coil then i can extract energy! the interesting part is, that if i increase capacitance on top (top load), then the output from opposing coil is much stronger 😎
i will make a video of this scenario in the coming days.
regards!
baerndorfer posted this 22 June 2026
Jagau posted this 29 June 2026
Excellent demonstration Baerndorfer.
 Yes, in the third video, adjusting the capacitance increases the effect.
Just a quick observation: have you ever done the same experiment without connecting the incandescent lamp to the base of the tesla coil, just the three LEDs at the output? The power consumption will decrease significantly. I noticed that the resonant frequency changes dramatically when a load is connected to the base of the tesla coil.
Jagau posted this 02 July 2026
The next experiments will be based on the analogy with the mechanical oscillator.
You can see the extra coil and its purpose there. The oscillator produces the scalar wave by its arrangement in opposite phase, the compressor is the extra coil.
worldcup posted this 12 July 2026
I usually try to understand the principle before moving on to the final step. I have a pretty good grasp of how the circuit(s) shown in the initial video work.
I haven't fully reached that stage yet, but progress is evident in other videos where we can see advancements before reaching this final stage.
Ref: https://www.beyondunity.org/thread/simplicity-and-power-of-ether/?p=2&order=all#comment-0247f2be-8d42-4325-b6aa-b41000b33ad1
Did the pachuka system work as shown over YT ? or that's another fake !
Jagau posted this 12 July 2026
That's a good question, one I can't answer right now, but his theory is correct.
I haven't yet reached his level of understanding; only experimentation will verify it.
He's very interesting to follow, and his experiments are constructive, given the limited resources he uses.
worldcup posted this 4 weeks ago
Any Update!
Jagau posted this 3 weeks ago
No recent developments on this subject.
