  • 16K Views
  • Last Post 20 hours ago
Jagau posted this 20 February 2023
My ferrites arrive this week, we will finally take interesting measures.
I believe that this circuit will produce something interesting according to the first tests.
In an order of ideas the DOC had also succeeded in making an eternal lamp, you will see the results soon.
In experimentation now, enough of the blah blah, i can't wait to see concrete experiences here.
Munny posted this 24 February 2023
Jagau,
Your SEC circuit has a basis on the two diode Avramenko’s Plug.  Something I have never seen anyone discuss is the physical distance between the two diodes.  We know transverse electromagnetic waves move at roughly 300,000 km/s.  If we change units to nanoseconds, this becomes 0.3 m/ns.  Thinking in terms of frequency and bandwidth, it got me wondering, maybe this distance between the diodes is a tuneable parameter.  Diodes switch based on voltage differential seen by the silicon junctions inside them.  Maybe we can optimize this voltage based on bandwidth for a half wave and drastically improve the performance of this relatively simple concept.  You mentioned your circuit is running in the megahertz frequency range and it occurred to me we are dealing with wavelengths practical for testing my hypothesis in regards to the Avramenko's Plug.  In addition to physical distance, we can also apply velocity factor of a dielectric material surrounding the conductor between the two diodes.  I have a hunch when utilizing Avramenko Plugs, we mostly never considered the physical (electrical/mechanical) implementation per se.
Jagau posted this 25 February 2023
Hi Munny
In experimentation mode, all the options must be looked at, including the one you are proposing.
I received my RF isolation ferrites beads and installed a new RF filter for the battery and the measurement instruments, results will follow soon.
Regarding the geometry of an av plug Alexander Frolov had noticed that the length of cable connecting that to the source circuit was very important.
The generator of changing potential is connected to the wire. Length of the wire must be corresponding to some resonance value. In resonance case potential changes in the point O are maximum. N.Tesla used special coil to find the resonance state in his single-wire power transmission system.
An interesting little document on AV plug
It should not however be forgotten that according to the DOC;
There are three parts to a SEC Exciter, TEM (conventional), Longitudinal, (conventional) and Spatial (unconventional). SEC is Spatial in that it can stimulate the 'Energy Lattice' (the foundation of everything  and cause an increased localized activity which results in energy being cohered into the exciter. The secret to SEC is to funnel this cohered energy into a localized load on the exciter.
Munny posted this 25 February 2023
I definitely like the term Chronal Field used in that document.  It coorelates perfectly with what W.B. Smith refers to as the Tempic Field.  I have always suspected this was the hidden, pervasive field most of us overlook.  When we think in terms of an object having potential memory, it tends to make the brain hurt.  The concept would seem to not only be a sound one, but should be obvious since potential cannot change instantly, anymore than mass can change instantly.
Not entirely certainly the below method is applicable, but it may be relevant as an alternate method for energy capture.
Capacitive Collection
If instead of capacitive plates, imagine using capacitive spheres.  Seems this would certainly be spacial in its implementation.
Jagau posted this 07 March 2023
SEC stands for 'Spatial Energy Coherence' and is a theory developed by the DOC, on how  'Exciters' are able to 'Cohere Energy' from as the 'Spatial Energy Lattice'.
When one is able to "cohere" grid energy and under proper circuit design, one can see a "coherent energy coefficient" CEC > 1.
SEC is not the circuit, the exciters are the circuits. Exciters do not produce beat frequencies below 4 MHz under all conditions.
The terminology used by the DOC is very explicited, CEC is for coherence coefficient and Pout / pin = CEC greater than 1 when the exciter is properly adjusted.
Munny posted this 12 March 2023
After watching Dr. Stiffler's Quantum Energy Receiver videos, I decided to build his easy version.   What I noticed were the magnets had no effect, but the device itself was most certainly detecting something.
Orgone Detector
This is nothing more than four 1N914 diodes connected as a full bridge rectifier, a 20KV 1000pF capacitor and a 10uF tantalum (polarized) capacitor.
When I connected it to my meter, I was rather startled by its behavior.
Orgone Reading
Yes, that is negative, completely counter to how we think a bridge rectifier should behave.  From my testing, this is normal for this device when it is just sitting ambient.  It will vary between -1.0 mV and -5.0mV.  When I bring my hand near this detector, the voltage will climb positive as one might expect, but the moment I move away, the voltage will again drop and go negative.
Dr. Stiffler mentioned Wilhelm Reich when talking about his Quantum Energy Receiver.  As we might recall, Wilhelm Reich did significant research in regards to orgone energy, also known as life force energy.  I will say for the moment, that's exactly what this little detector appears to sense.  What's disconcerting is in my location in a grounded metal building with metal roof and only incandescent lighting, no WiFi, I'm seeing a negative background.  If bringing my hand near this device makes the reading go positive and I'm not dead, having a background that is negative clearly tells me my life force is draining into the environment like a shunted battery.  This certainly corroborates how I feel most of the time--like I'm being drained.
The main reason for this post is somewhat of an alert.  It might be good for you all to assemble a similar sensor and have it monitoring while working with your devices.  If your coils happen to be drawing-in life force energy to make them behave as they do, that's energy your body isn't getting and probably needs.  I certainly do not know with any confidence what I'm actually dealing with here, all I can do is relay to you guys there may be something more to this research than we are aware of.
Fighter posted this 12 March 2023
Looking for more information about Dr. Stiffler's work I found this presentation made by a student for his university's assesment. He is presenting the basics and his understanding on how SEC 18x device work:
As a note the video have some technical issues, the sound is present only on the right channel not on the left channel.
Nevertheless, it's a very instructive presentation for Dr. Stiffler's concepts used when he built his devices.
Jagau posted this 12 March 2023
Thanks for the Fighter link, an interesting point of view.
I built the two most present boards from the DOC documents and the results are very encouraging with the SEC technology.
The exciter series 15 and serie18 are the most efficient. For the Sgate which is a diminutive of spatial gate, I am also building it, according to the DOC the sgate is the AC power equivalent of the Avramenko plug, a very nice project in progress.
No problem Jagau,
I'm adding here more resources I found, it's not in my intention to "spam" your thread but the information is directly related to SEC.
Here is a link with resources related to Dr. Stiffler's work:
https://emediapress.com/2019/01/24/dr-ronald-stiffler-thank-you/
Here is a (very long) thread started by him discussing about SEC:
http://www.energeticforum.com/forum/energetic-forum-discussion/renewable-energy/4067-high-voltage-from-thin-air
And also some documents uploaded by him on Scribd:
https://www.scribd.com/user/6820479/Dr-Ronald-R-Stiffler
It's all I got for now, I'm gonna go over this information to familiarize myself with Dr. Stiffler's work, concepts and maybe I'll find there some more important insights.
