  • Last Post 06 April 2026
AlteredUnity posted this 05 June 2025
Jagau posted this 07 June 2025
Some definitions that might help:
The word SEC is an abbreviation for:
Spatial Energy Coherence, SEC.
It is a theory developed by Dr. Ronald Stiffler covering the coherence, capture, recovery, and utilization of energy released and transformed from the ambient energy Lattice.
To successfully receive this energy from the energy lattice, an electronic circuit must be built.
A SEC Exciter
is a special Negative Resistance Oscillator design, which specifically generates a Ultra Wide Band spectrum of frequencies required in part to stimulate (excite) the ambient energy lattice, thereby allowing for the coherence of additional energy released by the ambient energy lattice.
And the way to calculate the input-output ratio is the CEC, defined by:
Cohered Energy Coefficient, CEC
the coherence, capture, recovery, or utilization or application of energy released and/or transformed from the Energy Lattice as a direct result of excitation and/or stimulation from one or more (SEC) exciters.
CEC% = ( Uout / Uin ) * 100 where Uout and Uin are expressed in Joule Seconds
Dr Stiffler words:
I do not believe in OU, what it should be called is CEC for 'Cohered Energy Coefficient', which is a far more accurate way of looking at things. A conversion of one energy form to another with a 'mathematical' gain. No creation of energy, just a cleaner conversion between forms.
Jagau posted this 18 June 2025
With this type of circuit, Dr Stiffler made a standard Colpitts Oscillator design followed by a MOSFET 2n7000 impedance matching driver to the AV Plug and load.
I am currently building this circuit and will experiment until coherence is achieved.
Inception posted this 19 June 2025
Note: Some of Dr. Stiffler's links are becoming extinct. One of the videos posted on page 2 of this thread is now private.
Videos: https://www.youtube.com/@StifflerDr/videos
Here are links to a mirror site that experimenters can copy for their own use:
http://www.tuks.nl/Mirror/Dr_Stiffler/SECDrivers.htm.html
http://www.tuks.nl/Mirror/Dr_Stiffler/SECExciter.htm.html
http://www.tuks.nl/Mirror/Dr_Stiffler/contents.htm.html
Also, the Tiny Spectrum Analyzer, TinySA, by SeeSii has a reduced price, with advanced models available.
This is a great find by Jagau!
Features of the TinySA Ultra+ can be seen here:
TinySA Ultra+
In the circuit above:
There are two L1's, two L2's, and no label for the inductor in series with the second L2.
Also, that series inductor is not connected to the second L2, so are we to assume that is an air gap, Jagau?
Jagau posted this 20 June 2025
Hello, Inception.
Dr. Stiffler's schematic is as shown. What he doesn't mention is that he used Litz wire, which is why we see two coils in a circle with one end unconnected. It's an open system. I did it and it works and are always in airisolation, no ferrite or metallic core.
About TinySA
Sorry to tell you that Amazon is now selling counterfeit copies of TYni SA under the seller SeeSii. They are poor copies. Don't buy them. Check the forums; they're full of problems.
Buy them here instead, on the wiki page of the inventor of the SA.
https://www.tinysa.org/wiki/
And here's how to use it on YouTube.
https://www.youtube.com/@ErikKaashoek
Erik Kaashoek is the real inventor of TinySA, not the Chinese.
Inception posted this 20 June 2025
I am waiting for an email reply from Erik, CEO of tinySA. Until then here is the tinySA wiki page:
Where to buy the tinySA Ultra or Ultra+
Zeenko store on AliExpress. This is the factory store. Select a Color to select which Ultra model
Eleshop in Europe
R&L Electronics in the USA. When the tinySA is listed as "out of stock" R&L can still take you order and only charge your credit card when the product is available again (which should be in a few weeks).
Switch Science in Japan
Mirfield Electronics in the UK.
astroradio in SPAIN
Neven in Central and Eastern Europe
Kami teknoloji in Turkey
Aursinc on Amazon
SeeSii store on Amazon
You can buy direct from SeeSii and the TinySa Ultra+ model is currently over US $100, so shipping is free. "Subscribe to emails and get 10% OFF"
Although the SeeSii Store is on the safe list, the SeeSii website is not mentioned. I also asked Erik about SeeSiiUS.com.
I will edit these posts when Erik replies.
Thanks for your help, Jagau.
Jagau,
Dr Stiffler's diagrams have different ways of describing things.
I understand that the L1/L2 coil is bifilar, but why is there an inductor without a label after that coil?
Is this
just another way of drawing this:
The Doc created several schematics that you need to experiment with to understand. This is the one that's basically used to understand. With 9 turns for the primary and the Litz wire for secondary, you adjust to the correct inductance.
The circuit in black was created by Mark McKay, a researcher who was experimenting at the time. It's not from the Stiffler doc. Read above in small black letters above the schematic in your document.
As for the TinY SA, look on the forums; you'll understand why the link on its wiki page isn't active.
Jagau posted this 01 July 2025
In following figure the components of each node depicts the potential oscillatory nature of the energy nodes, which can be set into oscillation by the correct stimulator or frequency of excitation. Doc Stiffler has in addition to the node structure shown various Open and Closed circuit examples. The Open circuit examples are the only configurations Doc Stiffler has shown to Cohere Energy from the Lattice.
Nodes with open and closed system representation with capacitors and coils arrangement.
I observed certain frequencies that appeared to always be present when Coherence was taking place.
The most difficult thing to find is to reproduce these frequencies which produce this coherence.
