  • 24K Views
  • Last Post 3 weeks ago
hackoa posted this 06 April 2026
Quoting:forest
The schematic in EasyEda format and the schematic in picture (black&white) looks a little bit different. Which one is correct ?
i made it, what is different?
forest posted this 06 April 2026
Connection from pin 6 of NE555 is  going to +12V in EasyEda schematic while in schematic from picture it goes to pin 3 (OUT) of NE555. The input voltage is of course not 5V but in range 13 to 24V. The pull down resistor int the line from OUT pin (3) of NE555 just after resistor 20k is 100k in picture while in schematic is 20k.
Capacitor from pin 2 (TRIG) of NE555 should not be 470uF but 470nF like in picture.  I've not checked PCB because I'm not using EasyEda (I use Kicad), but there are some problems there also, mainly the resonant capacitor and track widths are too small in mosfet section (but maybe it's because I imported schematic and pcb into Kicad)
I'm not sure if I spotted all differences, but the main question is which schematic is correct. From my (small) experience and AI chat it seems that original picture (tah one with black&white text) looks like more correct with regulating duty cycle.  it's SSTC schematic with antenna. The second stage I think is how to detect resonant frequnecy and adjust the output capacitor, I hope that is explained in Part 2 video.
Getza posted this 06 April 2026
Replying To: bunk
well, i try something like this ...., antena( long kabel), i do not have ground, so i use long kabel, lamp shine not at full brightness , consummation goes from 0,4A to 0,8A.
https://www.youtube.com/shorts/zHPZK4gOqAo
zaxtone posted this 06 April 2026
Avalanche effect - increase 😉
hackoa posted this 07 April 2026
Quoting:forest
Thank you, i saw my mistakes and make a correction.
evostars posted this 07 April 2026
Bunk Thank you for sharing so much inspiration with us here already!
I am getting good ideas from them and am building to test them.
I already used the coil on the 2 high voltage foils as a series capacitor plate which gives oscillations when the sparkgap discharges the foil.
Very strong discharge current!
Quoting:bunk
ENJOY (- Download video): -
How it is made? I have all the parts and can make it today. How is coil on the ferrit core wound?
worldcup posted this 07 April 2026
Quoting:bunk
Thanks.
@hackoa -
RINGER 3.0 IMPROVED WITH SCHEMATIC
Quoting:worldcup
Quoting:bunk
Thanks.
@hackoa -
Thank you my friend!
Getza posted this 07 April 2026
Replying To: bunk
Здравствуйте, BUINK! На видео видно, что вторая обмотка целая,
а на схемах она изображена как две противоположно направленные обмотки.
Какой вариант правильный?
На некоторых схемах фольга, являющаяся конденсатором, изображена прерывистой по длине,
 на других — целой и состоящей из двух половин.
Какой вариант оптимален?
Заранее спасибо!
