  • 24K Views
  • Last Post 3 weeks ago
andy2 posted this 15 March 2026
Thanks for the compilation. Where did you get G-stress? I only found E-stress ...
Inception posted this 16 March 2026
I searched for E-Stress and those files are all tagged E-Stress. 🤗
The ones attached here are snapshots of the E-Stress PDF files.
Does anyone have a complete PDF of these?
andy2 posted this 16 March 2026
Here is pdf E-stress.
But in your  pdf compilation is some other images called "G-stress". I am curious about them. Where are they from?
Like this one:
Getza posted this 16 March 2026
I post this is  explanation from @merlit1962 :
"Boys decided to comment on this, how to really quickly repeat 1 and 2 coils on a cardboard tube, it is important that the tube was paper.
 - 1 winding 0.3 mm copper
 -  2 winding 0.5mm  copper this is important!!!
        Further, on top of it, it has a 250 volt output, a thick wire of 4 square meters of copper, high current (amps) windings opposite !!!!
Now download SSTG ))) module, you can buy a model on Aliexpress, I don't remember
      It makes sense to send an AM modulated signal over a coil of thin wire (fish form signal-рыбки ), that is, a modulated 50 Hz signal with a high-frequency current, and it should be as high-voltage as possible!!
Type AM modulation  on  base of the transistor!!!
The supply voltage of the device is 9 volts, but through a step-up inverter, that is, a transistor is charged where it is 150 - 300 volts, the shorter ,the bigger ,the better!!!
By the way, this function is carried by a ferite coil that is separate from the scheme.
Well,  probably i  told you all about it.
All good!
worldcup posted this 17 March 2026
From my personal collection: 'Bunk' ran the forum https://hhobro.forum2x2.ru/. He had a habit of resetting the forum daily and banning members at random.
I've monitoring his official YouTube channel for years.
https://www.youtube.com/@missispots/videos
Inception posted this 17 March 2026
The G-Stress photos were from: Harish Singh Facebook but labeled E-Stress.
worldcup posted this 18 March 2026
Just for referece, some succesfull progress https://www.overunityresearch.com/index.php?topic=4510.msg118610#msg118610
Getza posted this 18 March 2026
АМ modulation.
hackoa posted this 20 March 2026
Here you can see some of the images and discussion:
https://energyscience.ru/topic517-189.html
also high resolution of images. I downloaded all posts of Merlit
Vasile posted this 30 March 2026
Quoting:bunk
Although, of course, you can ask me yourself, some of your questions, those related to my
invented devices.
Hello and welcome to the forum. I think the most important thing is for all of us to understand the principle of operation. Can you post a simple schematic of the principle of how your devices work? Something simple that the majority can replicate on their bench and understand how this devices work.
