  • Last Post 02 May 2026
zaxtone posted this 07 April 2026
Quoting:hackoa
Is this scheme? For me every word and every picture you post is interesting! I try to be energy independent many years download and save a lot of information.
This diagram, along with Tesla, was drawn by me from a black-and-white video. I want to warn that this diagram is correct, except for the part circled in red—this was my personal assumption in the initial attempt to understand the operating principle.
Mr. Bunk provided all the necessary 👉  materials.
Getza posted this 07 April 2026
"Ionization smoke detectors contain a tiny, safe amount of the radioactive isotope Americium-241''
Replying To: bunk
Yes. But its legality and availability are highly questionable. The same applies to mercury, although it can be extracted from a purchased device that can be easily purchased on websites with classified ads.
 or "'ртутный термометр""
Kdkinen kurtsvids posted this 08 April 2026
Replying To: bunk
Oh that's great and easy solution, thank you sir ! I will be working on this more tonite.
Replying To: forest
I think he mentioned some uncertainty and asked for basically a fool-proof diagram. But you do want to tie the loose end on the potentiometers so they don't ring and get burned out. If that was the thing you noticed.
This would be my first findings and tries with electrolysis on the Thoriated welding rods... As some may have seen from Bunk's posts, the use of radioactivity on the energized foil. I guess now I am forced to get a Geiger counter to see what this white insoluble stuff is. This video is not listed publicly.
hackoa posted this 08 April 2026
Is there anything else insted of mercury for use on the foil? Very toxic vapors and I`m afraid.
Maybe couple of aluminum foils and plastic between them could act like a capacitor again? What is your oppinion guys?
Replying To: hackoa
Your question reminds me to this, 2 parallel plates, but i am not completely clear, I think the red coil is the resonator of Tesla, not seeing a primary though. Maybe Bunk could explain.
And I tried to get this one working but I must be missing a major connection, i can get the ripping sound on the spark gap but not a single peep on the foil to ground.
is it a Single foil inside the core, Bunk ?
