  • 24K Views
  • Last Post 3 weeks ago
FInally after many years of long wait and arguments on OU, etc etc bunk decides to release the secrets.. ENJOY (Download video copy / materials before it vanishes from internet) ..Load up your kachers šŸ˜€
Pig Benis posted this 09 April 2026
Hello, Mr. Bunk.
After reviewing the entire thread, several things remain unclear, but first, I'd like to clarify two questions.
1. Why was nichrome used as the spark gap between the active and passive foils, and not some other metal?
2. In what wave mode does the coil on the cardboard tube operate?
Thanks!
evostars posted this 09 April 2026
A resistor limits conventional current. the spark gap is a high voltage event that changes fast. but it is a displacement current what it induces. so the resistance limits the one type of current so the spark gap can produce the other type of current (which can be longitudinal radiant)
andy2 posted this 09 April 2026
So the principle of Bunk's device is to get ionization and catch electrons on plates altogether with capaticing actions and two frequencies.
All in one.
Like in this image long time hanging on internet.
zaxtone posted this 09 April 2026
Quoting:evostars
I had Bunks last schematic translated to English.
on the left T1 transforms changing current into medium voltage for the load.
While to the right the tesla coil produces a high changing voltage on the foil,
which is capacitive coupled to the coil,
where a current is induced which loops into the load.
so if these induced current and induced voltage are in phase (resistive loads do that) than power is generated.
it seems doable. the two inverting circuits left and right need to run at the same frequency
 and at the right phase angle (inducing in phase voltage and current).
Interesting.
I added my thoughts between brackets  (...)
Thanks Bunk, any responce?
Dummyload posted this 10 April 2026
24 hours ago there were some posts up on this thread. One intriguing inductor, which warped my mind..  a documentary I did not get the chance to finish.. I beg leave these things up.
  • ScientificVoyager
evostars posted this 10 April 2026
Quoting:Dummyload
I added the translated picture of Bunk to my previous post
baerndorfer posted this 10 April 2026
after thinking about all this knowledge here i build a new coil like Bunk showed in his documents. my energizing part is different but this does not matter because the main effect in my opinion is the extraction of radiant energy which is produced somewhere.
diameter of coil is 70mm and height is around 160mm. the 2 pancake coils which work in parallel (the middle ones) are in series resonance with a 0.1uF HV/FKP capacitor at 69kHz. Vpp is only around 350V so not high.
the other 2 pancake coils are extracting from this resonance via diode-plug to a LED array (on right side).
now when i use the 2 copper foils to extract energy from the system i can do this WITHOUT DIMINISHING SOURCE DIPOLE. at the moment i cannot see, that the input is driving my additional load. it clearly comes from the copper foils.
now the intersting part is, that i cannot use a third foil which i put near this tower somewhere to replace the inner foil. this and other behaviours led me conclude, that the geometry itself must play an important role here. maybe it is 'only' a phase-difference thing between 2 foils in space or there is a deeper understanding which i do not have at this time.
the additional energy can be seen on the 2 cree-leds.
so from my perspective this is very interesting and i will investigate this further.
thx for posting these kind of ideas.
Fighter posted this 10 April 2026
Quoting:Dummyload
Hi Dummyload,
On our site a post can be edited or deleted only by its author or by an admin (me).
On my side I don't delete posts except the cases when there is spam in those posts.
Ocasionally I edit some posts just to fix some links or some YouTube videos which are not shown in those posts but I never modify the text of any post.
In this thread I didn't deleted any post, not sure what are you refering to.
