  • 24K Views
  • Last Post 3 weeks ago
Beginners Mind posted this 12 April 2026
Hi Baerndorfer,
Thanks for sharing your experiment.  Have you done any in/out power measurements?  Does your device rely on anything radioactive or toxic?  Much appreciated.
baerndorfer posted this 12 April 2026
Hi beginners_mind,
the measurement in this case is pretty simple. i need 12W for powering up the source which consists of some electronics and a L-C tank circuit. when i connect the load then there is no influence on input power. as i said.. it did not diminish source in any way.
i do this since 10 years and never felt sick or anything when working with HF devices. i do not measure radio activity.
i am still alive
Getza posted this 12 April 2026
Replying To: bunk
the file"'КАПАНАДЗЕ'  in your zip... ho made it?
it is in my language.....- български
Kdkinen kurtsvids posted this 12 April 2026
Can you describe it in a few short words? There was a few videos I was not able to load either. I still find it incredible. How Bunk can send these packets of videos and images All at once. I think he's supercharged his computer as well 😅
hackoa posted this 12 April 2026
Quoting:bunk
Very clever way to run the engine with water. No high amperage or high voltage. Just positive and negative charge and water molecule is split. Amazing.
zaxtone posted this 12 April 2026
Quoting:Kdkinen kurtsvids
Replying To: bunk
Super excited to be working on this. bless your heart Bunk. Im waiting for some equipment to arrive, but I've confirmed High radioactivity from the welding rods. And will be even higher measurements after separating the tungsten.
Work with it following all possible safety precautions. If even one microparticle gets into the lungs, mutation of lung cells is inevitable. Even welders sharpen their tools with particular fear before working, as the shavings and particles contained in it fly into the air.
Replying To: zaxtone
Yes I am aware, I plan to mix it into a paste which will not fly away to the air.
Quoting:bunk
I plan to give you a diagram of a device in Russian that does not require isotopes; but requires grounding!
It also works in the mode - SELF RUNNING!
Usually this device is on sale, on my personal forum....
The device is widely familiar in Russian forums;
but repeated originally only by me, and 3 more people.
A little later I will publish it in this very post!
This will be great !!! We appreciate it !!!
Replying To: bunk
Sir Bunk, we are ultimately forever grateful to you for your generosity.
Yes that forum was even difficult to follow, even worse if the manager is a doofus. Maybe he is Stephan Hartman of old overunity.com ? Ha
We are here busy trying to follow your work, trying to undo the old ways of thinking which you rightfully make fun of.
You may be feeling impatient with us, but i will have results soon. Im out of money so it may take another 2 weeks to get a few more materials, processing, then work to complete over top of the insides and "the stuff". The uncertainty is the permanence of the windings on top of the foils.
I won't easily be able to remove or correct anything inside unless the windings are removed.
And did someone say there's a bifilar winding? That confuses me greatly as I cannot see that anywhere.
Thank you sir Bunk. You're just such a good soul.
hi mr. bunk,
i like to know the url of your personal forum where you offer this device. thx and keep doing what you are doing!
