  • 24K Views
  • Last Post 3 weeks ago
Kdkinen kurtsvids posted this 13 April 2026
Here's some progress, and will get a baseline on output. First without radiation. All I really had for resonator is this 14awg solid, but we'll see.
Unimmortal posted this 13 April 2026
Quoting:bunk
-(chet) of this forum (overunityresearch) stinks of shit, he made his forum - closed; (so that the Bunk - does not read!...) 🤣
🤠 ! Promised by me on the previous page: -
Your opinions are your own, however know that Chet doesn't run that forum and has no control over it. Also, the forum is undergoing a cleanup... msg the forum admin for more info... Verpies @ OUR.
On a lighter note, I'm very much looking forward to replicating your success and learning. Thanks for sharing so openly.
MerLynn posted this 13 April 2026
Quoting:Kdkinen kurtsvids
Replying To: Beginners Mind
Wow you have action with the foils ? Awesome
Some 'theoreticals'.
Each metal has distinct Magnetic Properties.
Electricity is the flow of magnetic current except there is no 'flow'. Electricity is like the Vibrations of a Bell being hit 50 times a second only its a Magnet virtually hitting the iron core wrapped with wires.
Aluminium is the Vibration (Energy) Amplification metal. Its why it is used for High Voltage Power transmission lines. Being made by electricity at a specific Heat frequency, its easily excited by the Flux or Eddy Currents of  magnetic Field. On the miele we machined the glue they plaster the ends of the rotor coils with so as to get an aluminium disc as close to the Poles of the Windings on the motor. It generates without being spun. The housing of the motor was cut away to facilitate access.
On my last visit to Joe's I saw how Aluminium Plates were 'added' to a Miele washing machine motor and now that this principle of interacting with Aluminium can produce 'electricity' I can elaborate and maybe post some other ways to use Coils (miele motor) and aluminium.
The actual Tesla principle here is SEEING the eddy current reaction to Aluminium without spinning to get the same effect, namely vibrations in the aluminium as electricity. There are many ways to do this once you grasp the creation mechanism of eddy currents is electricity.
Eddy currents are created by the excitation of the crystal matrix of the 'collector' in this case aluminium but in a generator its the iron core of the pickup coils. The Tesla Coil can be A VIRTUAL INFINITY LOOP allowing Aetheric Energy to manifest as well as Physical Vibrational current or electricity. This thread design only has physical vibration electricity. There is wireless transmission of electricity through the 'medium' of the Wind Crystal Matrix as well just like between the 2 coils in a transformer. You want to play with electricity like Tesla, you must think in Fields created in a Vibrating Crystal Energy Matrix. The Rotating Magnetic Field Vital for any object to exist. paraphrasing Tesla.
Once you grasp this Tesla design, you can see that some manufactured Motors slip through the oversight committee with usable designs.
baerndorfer posted this 13 April 2026
i think about eddy currents that MerLynn talks about. as i understand the eddy currents are induced by a magnetic field which changes over time. if this is true, then there has to be a force that acts against the primary field. now when i look at Bunk's circuit and videos i can clearly see, that this is not the case. together with my own observation there is no back-force which operates against primary source dipole.
if someone has an idea i like to hear it.
Fighter posted this 13 April 2026
Can you describe it in a few short words? There was a few videos I was not able to load either. I still find it incredible. How Bunk can send these packets of videos and images All at once. I think he's supercharged his computer as well 😅
Yes, I guess some of Bunk's videos were made with some rare codec(s) which are not available on our computers therefore they cannot be played on our site like the usual videos.
But I tried and found out that converting them to the same format (MP4) in Video Converter and re-uploading them on our site fix the issue so they can be viewed on our site.
This is how the conversion options looks like:
I want to mention that just some of Bunk's video had this issue, the others are okay.
It's not Bunk's fault about that issue, the cause is just that rare codec some of the videos were made with and which is not available on our computers.
So if you encounter the issue just download the video on your computer and use the Video Converter.
It may work with other video converting applications you have available too, not only with this one.
Well, my post have actually more words (not fewer) but I needed to come with details... 🙂
zaxtone posted this 13 April 2026
You can skip the conversion. Simply install a 👉 codec pack 👈 on your computer to view.
Replying To: zaxtone
That's correct. But what I did (by converting and re-uploading) was to make that video playable on our site for everyone.
editor posted this 13 April 2026
is all like that?
Quoting:bunk
😜si es tan autosustententable como para moverse...
andy2 posted this 13 April 2026
Can I also post non sense videos in zip like Bunk here? Is there any mening of it? Every can see, that this was exact the faked video. His other videos are also faked? great ....
  • ScientificVoyager
At least I dont post fake videos, like someone else.
Are you trustworthy when you upload fake videos?
  • ScientificVoyager
