  • 24K Views
  • Last Post 3 weeks ago
Kdkinen kurtsvids posted this 05 April 2026
Replying To: bunk
Well they, and we all here definitely look to your work as most superior, and worth all efforts to achieve.
evostars posted this 05 April 2026
Thank you Bunk for sharing these inspiring devices with us!
hackoa posted this 05 April 2026
I have music Tesla from aliexpress and will try to use it because have AM modulation. The coil is with two pieces aluminum foil as per drawings. I dont understand why, but i see blink of the LED when i interupt the spark gap. With direct connection no lights. Also input is 50 Hz from phone signal generator, but no matter if i use the input nothing change. I tryed also slovakian scheme with extra coil on top of the Tesla coil. But because I`m not an electritian i lack a lot of knowledge about what i done Sorry about that. My experiments keep going. I`m open for recommendations what to improve if possible with this small Tesla. I also have and bigger Tesla coil katcher.
Getza posted this 05 April 2026
ScientificVoyager posted this 05 April 2026
Good morning, Mr Bunk. First of all, I’d like to thank you for sharing your work, as it’s very interesting. Whilst waiting for parts for my own project, which I’m also writing about on this forum, I decided to take a look at what’s been presented here. I have a Tesla coil with amplitude modulation, and I’ve also built a coil based on this diagram.
Connections 1 and 2 are the Tesla coil inductor. I’m not sure about connections 3 and 4.
I assume connection 4 is the ground for the Tesla coil circuit, but what about connection 3 (aluminium foil) – where should I connect it? To the drain output of the Tesla coil’s MOSFET transistor?
Brown cable is connected to ground of the building. Consumation is droping when connected to the ground. The lamp is 115V 6W.
Quoting:bunk
# 1 Replication Success
How to make it without ground?
In my configuration, the connections look like this
In my setup, the connections look as shown in the diagram. I don’t think terminal 3 should be connected to earth, because – as can be seen in various videos – the device works without it. Where should terminal 3 be connected?
Quoting:hackoa
Hi, are you using AM modulation in this experiment?
Quoting:bunk
bunk # 1 Replication 😎Success: -
and 😜
bunk # 2 Replication  ðŸ˜ŽSuccess: -
Thank you for the files; I’ll have a look at them.
