  • 32K Views
  • Last Post 10 January 2026
Vidura posted this 04 May 2024
Here anotherone, not copper but an interrresting design, for example from recicling a MOT transformer core:
https://hackaday.io/project/182504-diy-hv-variable-capacitor
Also the variable capacitors from old radioreceivers can be submerged in transformer oil, a good option,as this avoids streamers and dielectric leakage at high frequencies.
Fighter posted this 04 May 2024
I just want to add a very importand conclusion here.
Remember I started this experiment trying to demonstrate that Dr. Stiffler's tech and Don Smith's tech are using the same common phenomenon.
Quote from my first post in this thread:
As this experiment is successful I think I demonstrated the unification of these technologies.
The key to these devices and I think to all the overunity devices we're experimenting with here is the Heaviside component.
Let's take a look at what Don Smith told us:
allows magnetic waves to change back into useful electrical (coulombs) energy. Magnetic waves passing through the capacitor plates do not degrade and the full impact of the available energy is accessed. One, or as many sets of capacitor plates as is desired, may be used. Each set makes an exact copy of the full force and effect of the energy present in the magnetic waves. The originating source is not depleted or degraded as is common in conventional transformers.
Now let's take a look at my DSE device:
And let's take a look at Jagau's SEC device:
What do they have in common ? The Heaviside component generated along a coil and interacting with the Zero-Point/Aether/Quantum field like a interface facilitating the interaction with the devices.
Quoting from the observation made by Jagau here during his experiments with his SEC device:
...the optimization of the coils gives me a better performance when the 3 coils are in spatial arrangement all at 90 degrees.
The device as in my first experiences as you saw works ok but has better performance with the coils in mutual inductance cancellation at 90 degrees. The best performance was achieved with the L3 coil standing upright on the board, L2 left to right and L1 front and rear plane.
And one quote from my post here:
That is the source of extra-energy for all our devices and that's how our devices go overunity.
That is the key to the technologies we're experimenting with. That's the big part which Heaviside removed from the original equations of Maxwell and the reason he did that was not for simplifying those equations.
The reason "they" did that was to remove any possibility for the "offcial" physics researchers to design and build overunity devices. Why ? It's simple, that was a threat for Big-Oil's profit of hundreds of trillions made in the last 100 years.
The Heaviside component is not used in any of our current technologies. More than that in all the energy/electronic designs it's simply ignored or even worse there are technical adjustments made to suppress it !
In my opinion this is the key to all our overunity devices we're experimenting with  (probably ZPM is also using it in its own way, see the Micro-Generator going crazy when I start the ZPM in the second video here).
This interface is manifesting itself inside and outside the coil which created it and is providing a medium for the Zero-Point/Aether/Quantum field to provide energy to our devices, more specific to plates or coils placed at right angle (90 degrees) on its direction.
As I shown in the experiments with my DSE device, the energy it provides is not "seen" by the input and is not affecting the input at all. Combined with the single-wire energy extraction using Avramenko plug (demonstrated by Jagau in his experiments) is the way of applying what Tom Bearden told us: "Don't kill the dipole !".
Well, in our experiments both me and Jagau demonstrated experimentally this mechanism of not affecting/killing the dipole while we're extracting the energy through the Heaviside component interface from the Zero-Point/Aether/Quantum field.
In my opinion this is the key of our journey to Rome.
Jagau posted this 05 May 2024
Yes you are right Fighter,
it was Oliver Heaviside who discovered this vector flow of energy but unfortunately as Tom Bearden said, it was never taken into account by Poynting, and had been arbitrarily rejected by Lorentz. Unfortunately Lorentz's (the god of the time) abandonment of Heaviside's dark energy flow component has continued to be applied by electro-dynamicists today.
So we now know that it was Oliver Heaviside who was right so let's continue with his idea and finally move forward.
Fighter posted this 09 September 2024
As I wrote in this post, after dedicating a lot of time to the quantum cells experiments I'm putting them on hold and I'll resume the work on the DSE experiments.
I'll start building the customized capacitor for the next phase of the experiments here.
Fighter posted this 08 December 2024
Seems Joel started working on an experiment similar to mine. 🙂
Of course his device is a bit different than my DSE device (his capacitors are outside the coil while my capacitors are inside the coil) but they both use the same principle:
I really need to find time to work on my customized capacitor !
Edit: seems he's not gonna collect the energy through the capacitors but through the third coil; we'll see how the device will be connected during the experiments.
Atti posted this 06 January 2025
Please take a look at this layout.Interpretation.
andy2 posted this 06 January 2025
I think that if we take this capacitor plates forming capacitor as C and add L and make resonant LC tank circuit (probably at frequency same as the frequency of the plasma tube, we can benefit from it.
And also look at this patent
https://patentscope.wipo.int/search/en/detail.jsf?docId=MX94582
especially Fig. 4
There are coils not imaged in any Smith pdfs elsewhere on the internet when describing this patent.
Fighter posted this 06 January 2025
Thank you guys,
@Atti: yes, it's the same principle except instead of a plasma tube I'm using a coil with (relatively) high voltage pulses; but the principle works as I demonstrated, the energy from the Heaviside component can be extracted without affecting the input.
@Andy2: I see, seems it's a modified schematic of one of Don Smith's devices; I see the coil noted with 18, I'm not sure what note 21 is indicating, I'll need to read it carefully but it's very interesting:
I'll start rebuilding the customized capacitor (in a way to avoid the short-circuits between the plates) as soon as I return to Bucharest.
Darediamond posted this 04 March 2025
For a while I gathered information on what Don Smith called "The Don Smith Effect".
There is a Don Smith's patent number NL02000035 talking about a kind of transformer which is also not depleting the input source, just as you presented here with Dr. Stifflers's technology. The patent is in Spanish language but it can be easily translated using the machine translation:
I think that what Dr. Stiffler didn't realized is the fact that the secondary coils (the ones used to gather aether/zero-point energy energy) are actually used as capacitors (remember a coil is in the same time a resistor and a capacitor).
If I am right we are talking about the same phenomenon/effect and this can unify the technologies of Dr. Stiffler and the technologies of Don Smith.
What the patent says is: if you have a coil running at its resonant frequency and you put some plates at right angle outside the coil so the plates create a capacitor, the plates will gather energy without affecting/depleting the energy of the input source. It's the same thing you presented in your experiments using Dr. Stiffler's technology. From my research on this I think (I'm not sure if it's required) that the plates should be able to move closer or away from each other so they can form what we call a variable capacitor in order to be able to tune the device and get more efficient in gathering the aether/zero-point
But basically this is what Don Smith is talking about in its patent:
Don Smith's discovery is what he calls a "Don Smith effect", where the charge if put on one plate of the capacitor, it duplicates the same charge on the second plate from the ambient background (air and earth groundings). This forms an open system, where the input never gets depleted. Capacitor used determines the power output as he mentions. This is different from the conventional closed circuits where the source is grounded back to itself (in other words, sees"-" directly, the source is self-destroying).
A few images from the patent:
And here are two images I found showing the configuration from Fig. 3 (the image above):
I'll organize my material and my notes related to the Don Smith Effect and when I'll find some time I'll continue in this thread.
I have a few variable capacitors here which I bought from Thailand some time ago:
I don't know if I can use them in a Don Smith Effect experiment (Don Smith talks about plates changing distances to each other which is not how the modern variable capacitors work), but I intend to give it a try and create an experiment about the Don Smith Effect.
Seems the only way to gather aether/zero-point energy and to not affect/deplete the input source is to not have the source grounded back to itself (in other words, to not see the "-" directly, so the source is not self-destroying).
It's exactly what another of our teachers, Tom Bearden, told us: "Don't destroy the dipole !".
Because that's exactly what our official tech using symmetrical and closed systems is doing. That's why it will never be able to become overunity.
Jagau, I know I said I intend to replicate your device(s) from your experiment here related to Dr. Stiffler's tech but just replicating your work is not very helpful, maybe a better way is to work in parallel on a Don Smith Effect experiment and if I am right maybe we can unify the technologies these two great teachers demonstrated to us.
What you must first achieve in Don Smith Effect Infinite Wattage Output Gen is One Wire Output. It is with this you can charge Unlimited Capacitor Banks with 90V input.
I used 42Khz to pulse my 980 inches in length primary wire wound over 6 same length secondarys.All which are connected in series UpTo the single primary which is wound from left to right(CLOCKWISE).
High Frequency Diodes are a must. I am able to charger in a fraction 9f seconds as many caps that I wish to charge. My caps are 450VDC 250Uf.
I charge them all (upward of 200) in a fraction of seconds.
It takes less time to charge caps when using grounded High Voltage at High Frequency. You can ground High Voltage withouth One Wire Energy Transfer System or Shutting out Current from your Generator.
My Earth point is a well installed 10feet deep hole. I used 10mm or 1 cm thick copper plate. You can use Aluminum plate too. YOU MUST USE AT LEAST 10mm thick Pure Copper Wire to lead out your Eaarther coper plate. You can also Step-Down the High Voltage with Diodes and Bank Of DC Capacitors(my invention). It is totally Simply. The caps acts as voltage Divider. Say your output Voltage is 2500VDC USING 10 300V whatever if Capacitors in series, You will have 250VDC on each cap. No to get that 250V on each Caps out, connect diode to the Negative point of each cap and parallel the diodes.
andy2 posted this 05 March 2025
Quoting:Darediamond
What you must first achieve in Don Smith Effect Infinite Wattage Output Gen is One Wire Output. It is with this you can charge Unlimited Capacitor Banks with 90V input. I used 42Khz to pulse my 980 inches in length primary wire wound over 6 same length secondarys.All which are connected in series UpTo the single primary which is wound from left to right(CLOCKWISE). High Frequency Diodes are a must. I am able to charger in a fraction 9f seconds as many caps that I wish to charge. My caps are 450VDC 250Uf. I charge them all (upward of 200) in a fraction of seconds. It takes less time to charge caps when using grounded High Voltage at High Frequency. You can ground High Voltage withouth One Wire Energy Transfer System or Shutting out Current from your Generator. My Earth point is a well installed 10feet deep hole. I used 10mm or 1 cm thick copper plate. You can use Aluminum plate too. YOU MUST USE AT LEAST 10mm thick Pure Copper Wire to lead out your Eaarther coper plate. You can also Step-Down the High Voltage with Diodes and Bank Of DC Capacitors(my invention). It is totally Simply. The caps acts as voltage Divider. Say your output Voltage is 2500VDC USING 10 300V whatever if Capacitors in series, You will have 250VDC on each cap. No to get that 250V on each Caps out, connect diode to the Negative point of each cap and parallel the diodes.
Hi Darediamond,
thanks for the hints.
Is your primary coil connected to HV hF only by one end (other is open)?
Does your capacitor charge faster then 60Hz to be able discharge them at that frequency to the load?
Thanks in advance
Andy
