  • 32K Views
  • Last Post 10 January 2026
Jagau posted this 21 September 2025
Hello Fighter
In this photo of the capacitor you're making, I don't understand where your two capacitor wires are located.
We see one in the center and the other passing through all the plates. There can't be a capacitive effect connected like this?
On the other hand, if you connect each of the wires to each end of your capacitor, I think you will have a series capacitive effect.
Maybe this one is more explicit but we see the copper wire covering all the plates, I don't understand the capacitive effect??
Fighter posted this 21 September 2025
In your first photo that was just a temporary support while I've made the holes in plates so I've made sure the holes are aligning with each other; see the two thick double wires going through the holes - one going throught the holes of the copper plates and the other one going through the holes of the aluminum plates.
This is the assembled customized capacitor (not complete, more plates should be added but I have the issue of random contacts between copper plates and aluminum plates):
The carbon fiber rod in the center is just for mechanically fixing and aligning all the plates, it's not making electrical contact with the plates (I isolated it with scotch tape).
I just made a hand-made sketch with just two copper plates and two aluminum plates and the two wires to show how one wire is connecting the copper plates and another wire is connecting the aluminum plates:
When looking at the sketch please keep in mind that:
  • the v-shaped cuts in the copper plates are made to avoid their electrical contact with the wire connecting the aluminum plates;
  • the v-shaped cuts in the aluminum plates are made to avoid their electrical contact with the wire connecting the copper plates
This was the solution I've came with to avoid electrical contact between copper plates and aluminum plates but to still be able to electrically connect the copper plates together and the alumium plates together; that's why all that heavy and time-consuming work was necessary.
I don't know if I explained well, if something is unclear don't hesitate to ask me.
Yes, thank you, I understand now.
Your plates are all parallel, for a total of 2.5 nano farad, which is more than those of D.S., which were barely 10 pico farads. Thank you.
Fighter posted this 22 September 2025
Absolutely, you're welcome my friend !
Sorry, I try to organize my information before presenting it but I admit I'm not a good presenter and probably I would not be good as a teacher... but I do what I can. 🙂
I searched in this thread and I found here those variable capacitors' maximum values, they are about 0.61-0.65 nF. In the previous experiments they worked best (collected maximum energy) when they were set at their maximum values so I think those values should be used as reference.
Now, considering this capacitor is not complete (I still have a lot of plates to add after I find and fix the cause of the random connections between the plates), I guess the final value of this customized capacitor when completed will go above 10 nF.
Inception posted this 22 September 2025
If the shorts are difficult to see, try heating the teflon insulators until the edges are smooth and there are no rough edges to expose carbon dangling bonds.
Fernando posted this 23 November 2025
Hello Gman, last video, very nice, thanks for shearing with the group, I am working in this device to, the important and basic piece of that is the system is the  after the hv/hf is the FWBR and the GDT , like Zilano final disclosure and tesla colorado spring page 57, and paralell hv cap to the coil, after that It is all about magnetic and how to transform , rectified , stored to used. Thanks.
Sorry Figther for the interference in your thread.
Darediamond posted this 23 November 2025
The Don Smith Effect is Practically a ONE wire Output Earth Current Sucking Unlimited Electricity Generator. The Gen as I finally Decodes it is DANGEROUSLY POWERFUL!!
You simply have to follow Don's Instructions to make it Successfully.
Starting from the First Transformer which is stage one, the Primary Wire length is what determines the Frequency you will set your oscillator to. The calculation goes does: Wire Length(in feet) = frequency/998 998 is full Wavelength.
You can wind as many secondaries as you can under the primaries.
You must wind the Primary and Secondaries in same direction and connect them in series all tru so as to have One Wire output on the Secondary. I mean connect the overlapping Secondaries in series till the negative leg of the primary too. One leg of the Primary should go to the Positive of your Power Supply. The other leg should be connected to your NPN MOSFET for the Trafo to be Driving it at the Calculated Natural Resonance Frequency.
The second stage is the Capacitor Dam which determines the main Total Output Wattage.
Fighter posted this 24 November 2025
Sorry for the late reply.
@Gman, welcome to our site and thanks for sharing your experiments ! unfortunately for now I can't continue this experiment until I resolve some personal issues but I'll continue it as soon as I'll have some available time.
@Fernando, no worries, the discussion is about Don Smith's tech and this thread is exactly about that; glad to see you back ! ☺️
@Darediamond, thanks for contributing to this discussion and sharing your insights !
  • Fernando
Jagau posted this 31 December 2025
Hello Bri
I don't know if you have the 17 pages of relevant information on the DS effect.
It's an excellent thread for learning this effect.
